Related Articles
Middleware
Through a TagoIO middleware, companies can connect devices using their own protocol. The middleware acts as a protocol converter from any type (TCP/IP, UDP, ...) to the standard TagoIO APIs. For more information on how middleware is done, check our ...
Creating a Network integration
To create a new integration you must go to the Network management page and press the following buttonon the right side of the page. You only need to specify the network's name. Once you have the network created, you have several parameters that you ...
Senet Network
Using this article, the user will learn how to integrate a LoRaWan device with Senet Network and TagoIO. This setup is for the uplink operation: data sent from the device to your TagoIO account. The integration is accomplished in two parts: 1) TagoIO ...
The Things Network LoRaWAN™
This tutorial provides a step-by-step guide to integrate The Things Network (TTN) with the TagoIO Platform. By following these instructions, you will enable uplink and downlink operations, allowing data exchange between your LoRaWAN devices and the ...
Connecting your MQTT Broker to TagoIO
TagoIO supports MQTT connections through our MQTT Relay command-line tool. This software acts as a bridge between your MQTT Broker and the TagoIO platform, facilitating seamless integration and data flow. Developed in Rust, the TagoIO MQTT Relay is ...
