MQTT
MQTT
MQTT stands for MQ Telemetry Transport; it's an extremely simple and lightweight publish-subscribe messaging protocol. It was designed for constrained devices and low-bandwidth, high-latency or unreliable networks.
TagoIO has its own MQTT broker that is responsible for pushing data to clients in case something new is published in the specific topics they are subscribed to. For example, you can build a system where a sensor sends temperature data to a topic whenever it gets an update. Here, you'd have devices that would like to be notified when this data arrives, so they'd subscribe to this topic. When the data is ready, the temperature sensor publishes the data in that topic, and the broker is responsible for pushing it to all devices that subscribed to the same topic.
It's possible to combine MQTT with TagoIO’s amazing capabilities to also create dashboards, analytics, notifications, and reports
Security
Encryption across the network can be handled with SSL independently of the MQTT protocol itself. Additional security can also be added through application-encrypted data that is sent and received.
At TagoIO, you can send your data as encrypted directly to your Analysis, decrypt it there, and then insert the data into your Bucket. You can use this procedure to increase your security if your data is sensitive, or if you simply want to add an extra layer of security.
Connection
Host: mqtt.tago.io
TCP/IP port: 1883
TCP/IP port over SSL: 8883
username: Token
password: Your Device-Token
If the Device-token is removed from the device, or if it's deleted, it'll be disconnected from the MQTT broker.
Data flow at TagoIO
When you first send data through the MQTT to your device, you'll be able to visualize the connection and message through the Live Inspector on your device.
Those messages mean the connection is working, but nothing is being stored in your bucket yet. From this point, you'll need to create an Action with trigger MQTT and type Insert to Device Bucket.
Now you should see the data being stored in the Live Inspector
In this case, the variable is "payload" and it has a value of "22". If you don't send the data using the TagoIO data format, you'll need to normalize your data and change it to the correct format.
To do that, check out our documentation on how to use a Payload Parser.
More Resources
Here's a list of some additional documentation on MQTT resources:
    • MQTT - Example with MQTT.fx
      This is a tutorial on how to connect to Tago MQTT, subscribe to topics using wildcards and publish to a topic. For this tutorial we will use the software Mqttfx. To download and learn more about Mqttfx go to their ...
    • MQTT with Sensor Tag
      This is an example using the SensorTag Bluetooth module from Texas Instruments to send data to TagoIO. There is no code modification needed in the SensorTag side, and as it uses the MQTT protocol, only a configuration setup is needed. For the ...
    • MQTT - Publishing and Subscribing
      You can publish to your MQTT topics by coding a script that will run from an Analysis. When the analysis runs, your script can publish a topic that can be received by any device that has subscribed to that specific topic. There are different ways to ...
    • Trigger by MQTT Topic
      The trigger type, Trigger by Variable, allows you to execute your Action when data is sent to an MQTT topic. TagoIO has its own MQTT broker that is responsible for pushing data to clients in case something new is published in the specific topics they ...
    • MQTT - Process data, Publish it and Subscribe to a topic
      In this tutorial you are going to learn how to process some data, publish to a topic and subscribe to it. To subscribe to a topic we will use Mqttfx. To download and learn more about Mqttfx go to their website https://softblade.de/en/welcome/. ...
            Future and past Webinars
