Here is a quick tutorial showing how to add any LoRaWAN device through AWS IoT (Network Server). By following this tutorial, your setup will be ready to perform uplink operations (data from your device).
1. First go to your TagoIO account, and if this is your first device connected between AWS IoT and TagoIO, you will need to create an Authorization here . Copy it to use at AWS IoT later.
Note : you need to create only one Authorization for all your devices.
2. Go to your AWS console and access the IoT Core service.
Here you will need to go to Acts and create a new Rule:
When setting up the HTTPS endpoint, you will need to specify how you will be getting the Asset ID for this device. We recommend two ways, you can use your own rule as long the asset ID is sent after uplink/.
Now you can create the rule. After creating the rule, TagoIO will authorize your downstream and you should see “Enabled” in the rule list for your rule at AWS IoT.
3. This section describes additional steps you need to do if using AWS IoT LoraWAN
With your rule created at Step 2, we are assuming you’re using the endpoint for MQTT ClientID.
4. Now, you just need to start adding Device to your TagoIO account.
Go to Devices/AWS IoT, and choose the device connector from the list. Enter your asset ID - you can use the QR code to capture the EUI if needed.
Note: if the device that you are looking for connecting with TagoIO is not in the list, you can always select the Custom AWS IoT option and you can add the Parser for it later.
Done! Just turn your device and gateway on, and you will see data arriving in your account (data bucket of the device). Start building your dashboards, analysis, and actions!
If data doesn’t show up in your TagoIO account (use the Live Inspector tab in your Device to see data arriving), make sure you can see data in your AWS IoT console first, and check the keys and the configuration.
