Senet Network
Senet Network
Using this article, the user will learn how to integrate a LoRaWan device with Senet Network and TagoIO.
This setup is for the uplink operation: data sent from the device to your TagoIO account.
The integration is accomplished in two parts:
1) TagoIO Setup
First, go to the Devices module in our admin and look for Senet and select it.
Type a name for your device, select a data storage type and define a Data Retention, then click on 'Create device'.
2) Generating an Authorization at TagoIO
You will need to generate an Authorization at TagoIO so that it can be added into the Senet integration area.
This authorization can be generated by accessing the Service Authorization page.
Notes
The generation of an authorization code is crucial for being able to send downlinks since it allows TagoIO to authenticate downlinks.
3) Senet Portal Setup
Now, log in to Senet portal and go to your devices.
Choose the device to connect to TagoIO and click on the gear icon.
Go to "Notification Target".
Make sure the status is Enabled, select HTTP on the 'forward to' field. Fill the fields accordingly:
FieldDescription
NameEnter a unique identifier (e.g., tagoio-integration).
Forward To
HTTP
URLUse the endpoint format https://senet.middleware.REGION.tago.io. Replace REGION with your deployment region (e.g., us-e1eu-w1). For a list of available regions, visit TagoIO Network Integration.
HeadersAdd a header key Authorization and set its value to the authorization token you copied in Step 1.
Optional Data FieldsEnable RF Data and any other optional field you would like to receive in your device.
4) Setting up Downlink
In order to support Downlinks from TagoIO to Senet, you need an additional step.
  1. At the Senet portal, go to your Account Seettings, generate a Developer API Key and copy it.
  2. Now go back to the  Authorization page, where you created your authorization at step 2
  3. Click to edit the Additional Parameters of the Authorization.
  4. Paste your Developer API Key and press save.
Now you are all set, every time your device sends data to Senet, your data will be available at TagoIO.
    • Network Integration
      Your devices can always connect directly with TagoIO API using HTTPS or MQTT protocol. But, you can also connect them using different protocols to databases and web services by using one of this methods: Create a script that initiate access to ...
    • SenRa Network
      Using this article, the user will learn how to integrate a LoRaWan device with SenRa Network and Tago.   This setup is for the uplink operation: data sent from the device to your TagoIO account.  The integration is accomplished in two parts: 1) ...
    • Creating a Network integration
      To create a new integration you must go to the Network management page and press the following buttonon the right side of the page. You only need to specify the network's name. Once you have the network created, you have several parameters that you ...
    • The Things Network LoRaWAN™
      This tutorial provides a step-by-step guide to integrate The Things Network (TTN) with the TagoIO Platform. By following these instructions, you will enable uplink and downlink operations, allowing data exchange between your LoRaWAN devices and the ...
    • Connecting your MQTT Broker to TagoIO
      TagoIO supports MQTT connections through our MQTT Relay command-line tool. This software acts as a bridge between your MQTT Broker and the TagoIO platform, facilitating seamless integration and data flow. Developed in Rust, the TagoIO MQTT Relay is ...
