Loriot LoRaWAN
Loriot LoRaWAN
This tutorial provides a step-by-step guide to integrate Loriot LoRaWANTM  with the TagoIO Platform. By following these instructions, you will enable uplink and downlink operations, allowing data exchange between your LoRaWAN devices and the TagoIO application.
In order to complete the integration, you just need to follow the two steps below.
Step 1: Generate Access Token at Loriot
At Loriot Console, enter your Application and go to the Access Token section.
Click on Generate another authentication token, a token will be generated. Copy the Authentication Token to use in the next step.
Step 2: Create Authorization in TagoIO
  1. Access Authorizations:
    1. Go to Devices.
    2. Click on Authorizations at the top of the page.
  2. Create a New Authorization:
    1. Click the Create Authorization button.
    2. Provide a meaningful name for the authorization (e.g., LORIOT-Integration).
    3. Paste the Access Token you copied in Step 1 to the Additional Parameter field.
    4. Click Save.
  3. Copy the Authorization Token:
    1. After creation, copy the authorization token. You will need this in later steps.
Step 3: Set Up Integration in Loriot
Go to your Loriot console and create a new output. You can create a new integration under the menu Output > + Add New Output > HTTP Push
Select HTTP Push and fill in the following fields:
Configure the Output fields:
Field
Description
Target URL for POSTs
Use the endpoint format https://loriot.middleware.REGION.tago.io/uplink. Replace REGION with your deployment region (e.g., us-e1, eu-w1).
For a list of available regions, visit TagoIO Network Integration.
Custom "Authorization" header
Set its value to the authorization token you copied in Step 2.
To finalize, click on Save Output. Now that your integration with Loriot is ready, you can start adding the devices at TagoIO.
Notes
The endpoint https://loriot.middleware.tago.io/uplink points to the USA region. As we are committed to continuing support for this endpoint, we recommend that users in the USA region update their webhooks to https://loriot.middleware.us-e1.tago.io/uplink.
Step 4: Add Device in TagoIO
  1. Ensure Device EUI Consistency:
    1. When creating the device in TagoIO, use the exact same Device EUI that is configured in Loriot.
    2. The Device EUI must match exactly to establish a successful connection between Loriot and TagoIO.
  2. Select the Appropriate Network and Device Type:
    1. Choose the LoRaWAN Loriot Network during the device setup process.
    2. Select the correct device type from the available options. If your device is not listed, you can add support through connectors.
  3. Add Device Support via Connectors (If Necessary):
    1. If your device type is not available in the default list, enhance its compatibility by utilizing connectors.
    2. For more information on available connectors and how to use them, refer to the Connector Overview.
For detailed instructions on adding devices, visit the Adding Devices page.
Finalizing Setup
  1. Power On Your Devices:
    1. Turn on your LoRaWAN device and gateway to initiate data transmission.
  2. Verify Data Reception:
    1. In TagoIO, navigate to the Device and into the Data tab to confirm that data is being received.
    2. Alternatively, use the Live Inspector within your device settings to monitor incoming data in real-time.
With data successfully flowing into TagoIO, you can create and edit dashboards, add notifications, and create scripts to visualize and manage your device data effectively.
Learn how to perform downlink for LoRaWAN.
    • Adeunis with LoRaWAN™
      TagoIO supports most Adeunis devices by providing the perfect integration with several LoRaWAN™ networks. It also parses the data by extracting the value of the measured variables in real-time.  All data sent by your device will be readily available ...
    • Everynet LoRaWAN
    • Orbiwise LoRaWAN™
      This tutorial provides a step-by-step guide to integrate Orbiwise LoRaWAN™ with the TagoIO Platform. By following these instructions, you will enable uplink and downlink operations, allowing data exchange between your LoRaWAN devices and the TagoIO ...
    • machineQ LoRaWAN™
      This tutorial provides a step-by-step guide to integrate machineQ LoRaWAN with the TagoIO Platform. By following these instructions, you will enable uplink and downlink operations, allowing data exchange between your LoRaWAN devices and the TagoIO ...
