Orbiwise LoRaWAN™
Orbiwise LoRaWAN™
This tutorial provides a step-by-step guide to integrate Orbiwise LoRaWAN™ with the TagoIO Platform. By following these instructions, you will enable uplink and downlink operations, allowing data exchange between your LoRaWAN devices and the TagoIO application.
Prerequisites
Before you begin, ensure you have the following:
  • Orbwise Account: If you don't have one, register here.
  • LoRaWAN Device: Ensure your device is connect to Orbiwise and transmitting data.
Step 1: Create Authorization in TagoIO
  1. Access Authorizations:
    1. Go to Devices.
    2. Click on Authorizations
       at the top of the page.
  2. Create a New Authorization:
    1. Click the Create Authorization button.
    2. Provide a meaningful name for the authorization (e.g., MachineQ-Integration).
    3. Enter your Orbwise Username, Password and DASS URL from Step 2 into the Additional Parameters section.
      1. Format USERNAME;PASSWORD;DASS_URL
        Example:
        tagoio;iot;
    4. Click Save.
  3. Copy the Authorization Token:
    1. After creation, copy the authorization token. You will need this in later steps.
You must enter the username; password; host DASS url separated by a semicolon.
Only one Authorization per application is necessary. Don't do it for each device.
Step 2: Add Integration to Orbiwise
Go to your Orbiwise console and create a new Application. You can create a new application under the menu Application > Add Application > Manage Apps > Push Settings.
It will open a screen called 'Manage Apps', then click on 'Push Settings'. Fill in the following fields:
HostnameUse the endpoint format https://orbiwise.middleware.REGION.tago.io. Replace REGION with your deployment region (e.g., us-e1, eu-w1).
For a list of available regions, visit TagoIO Network Integration.
Port443
Host PassSet its value to the authorization token you copied in Step 1.
Make sure that you set the status of your Application to <Start Push>
Info
The endpoint https://orbiwise.middleware.tago.io points to the USA region. As we are committed to continuing support for this endpoint, we recommend that users in the USA region update their webhooks to https://orbiwise.middleware.us-e1.tago.io.
Step 3: Add Device in TagoIO
  1. Ensure Device EUI Consistency:
    1. When creating the device in TagoIO, use the exact same Device EUI that is configured in Orbiwise.
    2. The Device EUI must match exactly to establish a successful connection between Orbiwise and TagoIO.
  2. Select the Appropriate Network and Device Type:
    1. Choose the LoRaWAN Orbiwise Network during the device setup process.
    2. Select the correct device type from the available options. If your device is not listed, you can add support through connectors.
  3. Add Device Support via Connectors (If Necessary):
    1. If your device type is not available in the default list, enhance its compatibility by utilizing connectors.
    2. For more information on available connectors and how to use them, refer to the Connector Overview.
For detailed instructions on adding devices, visit the Adding Devices page.
Finalizing Setup
  1. Power On Your Devices:
    1. Turn on your LoRaWAN device and gateway to initiate data transmission.
  2. Verify Data Reception:
    1. In TagoIO, navigate to the Device and into the Data tab to confirm that data is being received.
    2. Alternatively, use the Live Inspector within your device settings to monitor incoming data in real-time.
With data successfully flowing into TagoIO, you can start creating Dashboards, Analyses, and Actions to visualize and manage your device data effectively.
Learn how to perform downlink for LoRaWAN.
    • Adeunis with LoRaWAN™
      TagoIO supports most Adeunis devices by providing the perfect integration with several LoRaWAN™ networks. It also parses the data by extracting the value of the measured variables in real-time.  All data sent by your device will be readily available ...
    • Everynet LoRaWAN
    • Loriot LoRaWAN
      This tutorial provides a step-by-step guide to integrate Loriot LoRaWANTM with the TagoIO Platform. By following these instructions, you will enable uplink and downlink operations, allowing data exchange between your LoRaWAN devices and the TagoIO ...
    • machineQ LoRaWAN™
      This tutorial provides a step-by-step guide to integrate machineQ LoRaWAN with the TagoIO Platform. By following these instructions, you will enable uplink and downlink operations, allowing data exchange between your LoRaWAN devices and the TagoIO ...
