TagoIO supports three runtimes for Analysis. Each runtime has different approaches to dependency management and development workflows.
All runtimes support the same TagoIO SDK functionality for working with devices, buckets, and other platform features. The main differences are in language features and how you manage external dependencies.
Deno Runtime
Deno runs TypeScript and JavaScript with built-in TypeScript support—no compilation step needed. The standout feature is remote imports: you can import packages directly from URLs without any bundling or upload process.
- import { Analysis, Device } from "jsr:@tago-io/sdk";
- import { DateTime } from "npm:luxon";
- import { z } from "https://deno.land/x/zod/mod.ts";
This means you can write your entire Analysis in the TagoIO editor, add imports as you need them, and run immediately. The editor includes linting and formatting to help catch issues early.
Dependencies are fetched and cached on first run, so initial executions may take a bit longer.
Node.js Runtime
Node.js runs JavaScript and requires you to bundle dependencies before uploading. Unlike Deno, you can't import npm packages directly in your Analysis code—you'll need to use the Analysis Builder CLI locally to create a bundle that includes all your dependencies.
- # Local development workflow
- npm install @tago-io/sdk axios
- tagoio-builder pack
- # Upload the generated .tago file
This approach gives you full control over your dependencies and build process, but requires local development tools. If you're already comfortable with Node.js workflows or have existing code to migrate, this runtime fits naturally.
Python Runtime
Python supports
remote package installation at runtime. When your Analysis runs, it automatically installs any imported packages that aren't part of the standard library.
- # /// script
- # dependencies = [
- # "tagoio-sdk",
- # "pandas",
- # "requests<3",
- from tagoio_sdk import Analysis, Device
- import pandas as pd
- import requests
- from datetime import datetime, timedelta
Just write your imports and TagoIO handles the UV installation behind the scenes. This makes Python ideal for data processing tasks where you need libraries like pandas, numpy, or scipy without the hassle of packaging them yourself.
The runtime uses standard Python package resolution, so you can import from PyPI just like you would locally. First runs will be slower while packages install, but subsequent runs use the cached environment.
Getting Started
Here’s the short path to get an Analysis running:
