Resource Limits
Resource Limits
TagoIO implements multi-tenancy as a cost-effective and performance-enhancing approach. This architectural choice brings a lot of benefits but it must have mechanisms to avoid service disruptions when other users utilizing the shared resources have spikes in their consumption. To prevent such scenarios, TagoIO limits the number of resources individuals can create in their accounts. When these limits are reached, the creation of additional resources will be blocked, to maintain platform stability and prevent resource exhaustion.
Limits for each resource
The limits for each resource are determined based on the specific plan you have. Please refer to the table below for detailed information on these limits for each plan.
AlertNote that most of these limits below are applied per Profile.
Resource type     /       Plan
Free
Starter
Scale
5
100
200
5
100
200
5
100
1.000
    Entity
5
50
80
5
100
10.000
1 / account
2 / account
5 / account
0
1
5
10
10
10
3
3
3
3
20
50
1
5
10
10
50
200
5
30
100
2
10
50
If you attempt to add additional resources after reaching your limit, a notification will be shown, indicating that you have run out of available slots.
If, for some special reason, your requirements exceed the limits in the table, consider upgrading your plan to Scale. If you are already on the Scale plan, please contact us through the Help Center.
Do you want to know more about our plans and services? Check our Pricing Page.
Monitoring resources across your entire account
You can monitor the amount of resources you have used by accessing the account menu in the top right corner of your Admin page and selecting the "Hard Limits" option.
    • Rate Limits (Hard limits)
      When executing requests to TagoIO, you will have a limit on the number of requests that can be made during a certain time period. These limits are applied in short intervals every minute, allowing us to provide a reliable and scalable API that our ...
    • Trigger by Resource
      The trigger type Trigger by Resource allows you to execute your Action when a resource meets certain conditions. A resource is one of the following: Access Management Actions Analysis Device RunUser For example, you can trigger an Action when a new ...
    • Allocating Services to profiles
      When handling multiple profiles in your account, it's essential to ensure each profile is allocated with the right amount of Services to operate efficiently. This can be managed on the Billing page under the 'Resource Allocation' tab. The services ...
    • Usage Policy
      When executing API requests to TagoIO by posting (data input) or to getting (data output) data, your account may face a limit policy based on the limits defined by you in the My Billing settings. The limits are based on the number of transactions ...
    • Python SDK
      You can access our SDK documentation on: https://py.sdk.tago.io/ Installation pip install tagoio-sdk Quick Start from tagoio_sdk import Account account = Account({"token": "your-token"}) devices = account.devices.list() Remote Imports in Analysis ...
