Authorization
Authorization
Authorization is used when you need to grant access to external services to your devices.
With a valid authorization, these services also have the ability to create new devices in your account. In this case, these new devices will show up in the list as "Unassigned ", making it much easier to scale up your applications.
Authorization is different from device-token.
Use authorization only when integrating with external services, such as LoRaWAN or Sigfox.
Use device-token when connecting directly with HTTPS or MQTT.
Generating an Authorization
To generate an authorization , go to your Device section and click on 'Authorization'.
In the next screen, enter a name that you can identify later, enter additional parameters (if requested by the integration), and press the Generate button.
Only certain integrations require 'Additional Parameter'. Check out a list of integrations to learn the parameter needed for each provider.
Once the authorization is created, you can copy and paste it into the external service portal.
How to use the authorization generated depends on the service that you are integrating. Here you can see a list of service integrations.
    • Senet Network
      Using this article, the user will learn how to integrate a LoRaWan device with Senet Network and TagoIO. This setup is for the uplink operation: data sent from the device to your TagoIO account. The integration is accomplished in two parts: 1) TagoIO ...
    • Everynet LoRaWAN
    • machineQ LoRaWAN™
      This tutorial provides a step-by-step guide to integrate machineQ LoRaWAN with the TagoIO Platform. By following these instructions, you will enable uplink and downlink operations, allowing data exchange between your LoRaWAN devices and the TagoIO ...
    • Sigfox
      Sigfox is a relatively low-cost wireless network technology that requires low power to connect, and that is implemented by lost cost hardware modules. This tutorial provides a step-by-step guide to integrate Sigfox with the TagoIO Platform. By ...
    • Loriot LoRaWAN
      This tutorial provides a step-by-step guide to integrate Loriot LoRaWANTM with the TagoIO Platform. By following these instructions, you will enable uplink and downlink operations, allowing data exchange between your LoRaWAN devices and the TagoIO ...
