TagoCore Clusters allow you to connect multiple instances to a single Cluster system, enabling you to manage and control multiple TagoCores.
One of the main advantages of the Cluster system is that every instance inside of the cluster is in a constant state of synchronization with other instances, which means that if you, say, Install a Plugin in one instance, all others will also install that Plugin.
