Connectors enable you to create a device with built-in behaviors that allow it to communicate with a Network very easily.
They also help you automate and scale your devices, once you create a device using a connector, that device will also run the payload parser of the connector to decode incoming data.
Creating a connector
To create a new connector you must go to the Connector management page and press the following button
on the right side of the page.
You need to specify the connector's name and the networks that it belongs to.
You can specify as many networks as you like as long as at least one is selected.
Once you have the connector created, you have several parameters that you can use. If you want to keep the network private for your account only, you don't need to fill all of them.
- Name: Connector name.
- Description: Connector quick description.
- Logo URL: Image of the sensor or logo of the company.
After you create a connector, it will only be visible to you by default. However, you have the option to share it with other
Profiles from different accounts. Read more about
Sharing Connectors & Networks.
Documentation
Here is where you can provide more detailed information about your connector.
- Description: Full description of the device, we recommend describing device functionality and adding the link to the device datasheet.
- Completion Text: Information that shows up right after the device is created. You can leave it blank to not show up, or enter information on what to do after the device was created.
It's recommended to add a link for dashboard templates here. - Device annotation: The text here will always be available for the user when they access their devices page.
It's recommended to add links for dashboards templates here.
Device Parameters
Device parameters are useful ways to set some parameters to connectors created using your connector.
You can set it as a Number, Text, Dropdown, or Switch, which you can access later in the payload parser.
Here is an example with a dropdown on how it looks in the user view:
Check the Payload parser context overview to know how to get this information on the payload parser.
Payload Parser
The payload parser for the Connectors doesn't work any differently from the payload parser for devices. All same rules are applied here.
Related Articles
Publishing, updating and accessing decoders
TagoIO provides a list of pre-integrated IoT devices for easy connection. However, due to the vast array of manufacturers and ongoing sensor development, you might not find a connector for your specific device. In such cases, you can create your own ...
API Overview
It is easy to connect devices, data sources, or third-party APPs to your account using TagoIO Application Programming Interface (API). We have a comprehensive set of APIs that gives you full control to manage your accounts, data, devices, dashboards, ...
Dashboard Overview
A dashboard is where you place your widgets to visualize and interact with data, all in real-time. Dashboards can also be shared with end-users that will access your application using TagoRUN. All your dashboards are listed on the sidebar of the ...
Analysis Overview
Services Overview
TagoIO offers a broad range of services that can be allocated the way your applications needs it to be. By provisioning the services that each Profile will use throughout the month, you will know exactly how much you will be charged. You can ...
