Payload Parser
Payload Parser
The Payload Parser handles the raw payload sent by the devices in order to extract the measured variables. For example, it can be used to transform an HEX payload sent by a device into temperature and battery levels.
You can also use it to handle the payload in real-time, allowing the conversion of a value to the desired unit. For example, if your data contains a temperature in F, you can use the parser to convert it into before inserting the data into the Device.
You can learn about the differences between Payload Parser and Analysis.
TagoIO can run up to two parsers: one that is defined by the Connector (added during the creation of the device) and your own parser (optional).
The parsers are executed in sequence. First the one from the Connector, then your parser.
The connector type is defined based on your selection from the list of devices (Add Device step). It contains the script necessary to work with that device.
Parser settings to enable the parsers
The script contained inside the parser from the Connector is not visible.
How is the Payload Parser triggered?
The payload parser is automatically triggered every time the device sends data to TagoIO (no need to setup anything). Your payload parser is the first step that gets triggered before saving data in the Device's data storage, so if your code has an error it will be returned directly to the device HTTP post response.
There are some concepts about global variables and context that you may want to learn.
A parse example
For this example, let's connect a toaster to Tago.
A toaster could send data to TagoIO when your bread is toasted in the following format:
The value above could represent XX YYY ZZ.  Where:
ValuesRepresentation
XX00 - Interrupted, 01 - Successful
YYYTemperature in Fahrenheit
ZZError code or 00 - No error
That value is good enough for machines or engineers, but for humans, it doesn't mean anything and also it's not optimized for the Tago Dashboard. Therefore, we need to parse this payload.
Let's code the Payload Parser to transform that payload into real variables. First, click on your Device and go to the Payload Parser tab.
On the Payload Parser tab you will see the code editor. Then, you can write the following code:
Save, and you are ready. Now, every time the toaster sends those variables, the parser will transform it in real variables, and you can use them to build Dashboard, Analysis, or Action.
Learn more about  Building your own parser function.
    • Payload Parser Troubleshooting
      When using the Payload Parser on TagoIO, you might run into some common problems that stop the parser from decoding your device data correctly. This means the data won't be saved on TagoIO. These problems are usually related to mistakes in how the ...
    • Payload Parser timeUtils Library
      The timeUtils is a powerful library available as a global variable in the Payload Parser, designed to simplify the timezone conversion and manipulation. It offers a set of functions to convert, format, and manage time information with ease. Available ...
    • Payload Parser - Context & global variables
      If you are going to create your own parser, you need to understand how context works. When you start writing your own Payload Parser, you can use certain globals variables in your code. Think of these global variables as variables that you can access ...
    • Publishing, updating and accessing decoders
      TagoIO provides a list of pre-integrated IoT devices for easy connection. However, due to the vast array of manufacturers and ongoing sensor development, you might not find a connector for your specific device. In such cases, you can create your own ...
    • Building your own parser
      In this tutorial, you will learn how to convert (parse) a raw payload sent by a device into actual measurable variables.  Data flow structure You can create parses for devices that weren't found in our list of Devices, so that you had to use a ...
