Adeunis with LoRaWAN™
TagoIO supports most Adeunis devices by providing the perfect integration with several LoRaWAN™ networks. It also parses the data by extracting the value of the measured variables in real-time.
All data sent by your device will be readily available to be displayed or processed in your Analysis.
You can check if a parser script was added to your device under the tab 'Payload Parser'.
To add a device, just go to Devices, click on 'Add Devices', and filter network by the LoRaWAN™ provider you will connect, and pick your device from the list.
The configuration setup will vary depending on the LoRaWAN™ provider.
Select one of the following options to continue your integration:
After you have completed the setup above, you will be ready to move forward.
Now, just turn your Adeunis device on, and wait for the data to hit your data bucket. Every time the device sends data, the parser will be executed, the extracted data sent to the bucket, and it will be ready to be shown in the dashboards.
You can start to build your dashboards immediately.
Also, you can create notifications and more advanced scripts as needed.
Enjoy your Adeunis device with TagoIO!
    • Adeunis with Sigfox
      TagoIO supports most Adeunis devices by providing the perfect integration with Sigfox backend. Also, it parses the data by extracting the measured variables in real-time. Adeunis + Sigfox + TagoIO diagram All data sent by your device will be readily ...
    • Everynet LoRaWAN
    • Orbiwise LoRaWAN™
      This tutorial provides a step-by-step guide to integrate Orbiwise LoRaWAN™ with the TagoIO Platform. By following these instructions, you will enable uplink and downlink operations, allowing data exchange between your LoRaWAN devices and the TagoIO ...
    • Loriot LoRaWAN
      This tutorial provides a step-by-step guide to integrate Loriot LoRaWANTM with the TagoIO Platform. By following these instructions, you will enable uplink and downlink operations, allowing data exchange between your LoRaWAN devices and the TagoIO ...
