Security and Protection for RUN users
With TagoRUN, you can provide actions and methods to increase your application's security and protection for your Run users, as well as make your application comply with the main laws regarding data privacy and security by providing your end-user safeguards to prevent inappropriate access to their personal data.
By accessing your Run module and selecting the tab 'Security and Protection', you will be able to implement and customize how the account delete requests will be processed, enable two-factor authentication, define the requirements for creating passwords, and protect your application against robot activities.
Delete request process
Deleting end-user data is a significant decision for an application, and TagoIO wants to help you make the best choice. In doing so, you can define which processes the user must follow in order to delete their account.
You can choose to enable the following options:
- Send an email to the profile owner: you can receive an e-mail and manually process the request through the User Management module.
- Immediately delete user account: you can consent to TagoIO to process the request and immediately delete the user account.
- Run an Analysis: you can implement a script to analyze and process the requests using Analysis and our SDK.
TagoIO will never remove any Run User data without your consent. To allow the immediate deletion of an end-user, you must activate the option 'Immediately delete user account'.
Two-factor authentication
Allows your end-users to add an extra level of protection to their accounts by requiring more than just a password, but also a second authentication mechanism that only the user knows or has access to. Once enabled, Run users can access their Account Settings and configure the authentication method, similar to Two-factor Authentication on Admin.
You can enable the following authentication methods:
- App Authenticator
- SMS*
- E-mail*
*Notice that each email or SMS sent to Run users will be counted as 1 transaction from the respective service. Make sure to allocate the right amount of these resources to your profile. Read more about Allocating Resources to profiles.
Password strength
The strength of a password is a measure to define how hard it will be to gain access to an account through brute force or simply guessing. You can define mandatory password requirements for your Run users when they change or create a new account, and the following requirements are available:
- Must contain upper and lower case letters
- Must contain a mix of letters and numbers
- Must contain special characters (@, !, &, ...)
- Minimum length required
Captcha
Protect your application against non-human actions by requesting captcha tests on Sign In and Sign Up. Distinguishing human visitors from robots to prevent activities like web scraping, spamming, and brute-force password attempts.
Related Articles
Run Theme
You can customize the appearance of RUN and build up your application with your own color palette. 1. Signup page On the Signup page, you can modify colors, background, and the logo that is displayed. It is also possible to have the background as an ...
Notifications for Users using Analysis
The Analysis is always a powerful tool when it comes to TagoIO, and that does not change for Notifications. Here you will learn how to send a notification for your TagoRun users using Analysis, how to use buttons, and how to handle user decisions ...
You can push notification messages directly to the users registered in your TagoRun application. This article will guide you on how to send notifications to your users using Actions or Analysis. Notifications for users are not much different from ...
User Engagement
You can also use third-party analytic tools to track and engage with your RUN users. The Integration module located in the RUN session enables an easy setup with lead softwares like Google Analytics and Zoho. Some softwares will bring more than ...
Google Analytics
You can easily integrate your RUN application with Google Analytics to track users and get insights. All you need to do is to use your Tracking ID in the RUN setup. To integrate, just follow these steps: Create an account at ...
