Allocating Resources to profiles
If you have more than one profile created in your account, you need to allocate (distribute) each available resource to the profiles.
The resources are limited inside of each profile, so that when a service usage goes beyond the limit setup for it, only that profile will be blocked.
When there are not enough resources available to be allocated, you will need to increase the overall limit of the services on your account, or reduce the limits on the other profiles. Access the My Billing page to upgrade these services.
Related Articles
Profiles
Profiles are similar to having different sub-accounts under your own main account. You can create multiple profiles for persons or organizations and then share them with others. By doing this, you will continue to own the 'sub-account' while allowing ...
File storage service
You can use our Files module to store any type of files for reports, videos, logos, background images, and more. The File service is measured by the overall size of all files stored in your profiles. If any of your profile reaches the limit of size ...
End-Users service
Each end-user that is added in the User Management list is counted as an end-user. End-users, also called RUN-users, can be automatically added when they sign up in your RUN application. If any of your profile reaches the limit of end-users ...
Billing Summary
You can get an overview of your account's costs for the current month by clicking on the Summary tab. This view helps you to track the cost of sub-accounts (profiles) that you may use to bill your own customers. This page is composed by three views: ...
Setup Billing
To setup your billing, just go to the top right menu (just under your avatar) and click on My Billing. Once you are inside the My Billing page, select the Billing Information tab in order to fill in the company name, address, and any other ...
