TagoRun
TagoRun
The Run module allows you to create and deploy your solution using a customized logo, colors, URL, sign up page, e-mail messages, and more.
Run works synchronized with the Access and User management modules. When you configure and deploy your solution, a domain will be created for your application so that users can sign up.
Platform customized with your brand
By default, the your url may be a subdomain of run.tago.io (e.g. mycompany.tago.run) or a fully customize url using your current company domain (e.g.  portal.mycompany.com).
With Run you can setup three main things:
1. Your Run  (Application portal)
Go to the Main Configuration and Domain tabs to configure the title and sub-title of your application, add a favicon (browser icon) and logo, and edit the colors used in the navigation bar.
More options to edit color for Buttons and General themes are available in the Advanced Configuration tab.
You can add pre-programmed buttons that will be located on the Sidebar (menu on the left side). These buttons will be available to all users. You can organize up to three in the same row.
An action can be associated with each button:
  1. Open a dashboard- select a dashboard from your list.
    Tip: You must grant access to users using AM.
  2. Show iframe or html- enter a valid url (https only). Some examples:
    1. Add a url of a Googlesheets will make it available to everyone in the main dashboard area
    2. Add a url of an embedded widget from TagoIO
    3. Add a url of your company documentation or support webpage
2.  Your Sign up page
In the Sign up page, you can edit the color of the buttons and text, select an image, video, or color for background, and define opacity for the form.
On top of the required fields of the forms, you can add customized fields for the user. Learn more about Signup Fields.
There are three methods for signing up:
  1. Anyone - anyone that signs up will receive an email asking for confirmation. When the e-mail is confirmed, the user will have access to the portal.
  2. Confirmation Required - after the sign up, user receives an e-mail indicating that the administrator will analyze the request. The administrator needs to approve the User manually.
  3. Disabled - the option Sign up is removed. Administrators should register users using the User Management module.
You can also add a link for users to read the Terms and conditions of your solutions / company.
3. E-mail templates
You can customize the messages that users will receive after they sign up in your application.
You can customize the Welcome e-mails as you wish, use the editor to add text, links or even images. You can upload images in the Files.
Tip: use the button 'Send test e-mail' to receive a sample of the e-mail in your own e-mail address.
    • TagoRUN Mobile App
      Our TagoRUN mobile app is suitable for end-users to access the applications designed by companies and developers. It is easy to operate it and it allows a high level of customization. Download TagoRUN App from AppStore or GooglePlay. A custom mobile ...
    • User Management
      You can visualize and control all users that sign up in your application under the User Management module. When you create and deploy your solution using TagoRun, all users that sign up will be listed in this area. You can grant or remove access, ...
    • Notifications for Users
      You can push notification messages directly to the users registered in your TagoRun application.  This article will guide you on how to send notifications to your users using Actions or Analysis. Notifications for users are not much different from ...
    • Run Theme
      You have the freedom to personalize the look and feel of the RUN interface, allowing you to craft your application using a unique color palette that resonates with your style. To get started, access the Run module and navigate to the Theme tab. The ...
    • Branding and Deploying Applications
      Use the Run module to deploy your own IoT Platform for your end-users. The options available in your RUN will depend on your current plan and the add-ons selected. Even the Free plan offers a great level of customization. 1. Deploying Your own ...
