Two-factor Authentication (2FA)
Two-factor authentication (2FA) adds an additional layer of security to your account by requiring more than just a password to sign in. It requires and provides another form of authentication that only you know or have access to.
This form of authentication is a six-digit code that's generated by an application on your mobile device or sent as a text message (SMS or E-mail).
The SMS and E-mail authentication methods are available only for Starter or Scale plans.
Once this method is configured, you will be requested to type the code when trying to Sign In, or when generating a new Account Token.
You can choose the method that fits you best when prompted by clicking on the message "Can't access your two-factor device?"
Keep your Admin account safe with this awesome feature.
Related Articles
Horizontal Bar Widget
Charts are a very powerful way to visualize your data and look for insights. You can also customize colors, apply Formula, decide if they're to be stacked or not, and more. This widget also accepts features like metadata and series, that can be set ...
Vertical Column Widget
Area Chart Widget
Charts are a very powerful way to visualize your data and look for insights. You can also customize colors, apply Formula, customize the line shape (step or smooth), and more. This widget also accepts features like metadata and series, that can be ...
Multiple Charts Widget
Charts are a very powerful way to visualize your data and look for insights. You can also customize colors, apply Formula, customize the line shape (step and smooth), decide if they're to be stacked or not, and more. In a multiple charts, each ...
Profiles
Profiles are similar to having different sub-accounts under your own main account. You can create multiple profiles for persons or organizations and then share them with others. By doing this, you will continue to own the 'sub-account' while allowing ...
