Sharing Dashboards
Sharing Dashboards
A great feature from TagoIO is its native sharing capability for dashboards, because we know that sometimes a dashboard can become an entire feature that you want to share.
If you want to share only the template of your dashboards, use the Distribute feature.
To share applications with your end-user using your brand and custom URL, use the TagoRUN.
To share a dashboard, open the menu for the dashboard you want to share and click on Share Public. As shown below:
The Share Public section can also be accessed by opening the settings page when accessing the dashboard on your Admin.
Dashboards can only be shared once you activate your TagoRUN portal and create an Anonymous User.
Share Public
You can share your dashboard with anyone that receives an URL link. It will not be necessary for the other users to have an account created at TagoIO, or any credentials to sign in. You will need to activate your TagoRun and create an Anonymous User to be able to share your dashboards.
The Anonymous User should have the necessary permissions to access the resources you want to display in your public dashboard. You can do that by creating a a policy in the module Access Management.
A public link can be copied from the Share Public page for both Normal and Blueprint Dashboards.
If your Profile does not have the TagoRun deployed or an Anonymous  User, the Share Public section will display the instructions will need to follow to meet the requirements.
Dashboard Templates
You can also share the template of your dashboard using the distribute feature. In this case, no data is shared, only the template.
    • Grouping Dashboards
      You can group related dashboards using dashboard tags. To do so, go to “Dashboard”, click on the gear icon to edit it, then on the section “Tags” create a new tag. After that, on the section “Group dashboards using Tags” select the grouping tag. To ...
    • Distributing Dashboards
      You can share a template of your dashboard, without any of your data, and send a link to anyone to add a copy to their account through a customized install page. After that, they will be able to modify the dashboards as they wish. When people access ...
    • Sharing Connectors & Networks
      TagoIO offers a vast selection of pre-integrated devices and networks, allowing you to easily connect your device. However, with the constant development of new devices and networks, creating a custom Connector or network integration may be ...
    • Downlinks using Dashboards
      Learn how to perform downlink for Class C or A devices using Analysis. Also, we will show how to send downlink data from dashboards. This approach can be used in the following cases: For devices with class C: to immediately send a downlink message to ...
    • Team Management - Sharing your profile
      You can grant access to other TagoIO accounts to any of your Profiles by using the Team feature. By adding others to your team, they will have access to all the applications that run on that profile.  The invitation can only be sent to emails that ...
