Data Output for dashboards
In TagoIO, each time someone accesses data from the Dashboards using TagoIO Admin or TagoRUN, a data output is counted for each variable displayed. For instance, when an end-user loads a dashboard that displays 3,000 registers, this same number will be counted against your dashboard's output limit. This counter is totally separated from the Data Output service
The data output limit for your dashboards, predefined by your plan and applied to each profile, resets every month. If attempts are made to visualize data from your dashboards once this limit is reached, an error will occur. Please refer to the table below for detailed information on the output limits for each plan.
Plan
Data Output for Dashboards (registers)
Free
3,000,000 / month
Starter
15,000,000 / month
Scale
50,000,000 / month
Data consumed by the dashboards will not be counted against the Data Output Service.  You are not billed by data output for Dashboards.
What happens when I reach the limit
When your account approaches the predefined limit, you will receive a notification suggesting an upgrade to your plan. This notification will be sent to your Admin panel and to your registered email address. Notice that you cannot increase the limit of the data output for dashboard by yourself (differently from the limit control that you have for the general Data Output Service).
Customers on the Scale plan can request an increase in this limit by contacting our Sales Team or opening a ticket through our Help Center.
Monitoring your limit
You can monitor the amount of your dashboard's data output that has been consumed by accessing the account menu in the top right corner of your Admin panel and selecting the 'Hard Limits' option - search for the row "Dashboard Output".
    • Data Output Service
      One transaction of Data Output is counted for each register read from a device's data storage. Learn more about Getting Data. You need to define the Data Output limit per month for each Profile where your applications are running. Here is one ...
    • Sharing Dashboards
      A great feature from TagoIO is its native sharing capability for dashboards, because we know that sometimes a dashboard can become an entire feature that you want to share. If you want to share only the template of your dashboards, use the Distribute ...
    • Widget Cache system
    • Distributing Dashboards
      You can create and share a dashboard template—either without your personal data or using mockup data—and send a link so that anyone can install it into their account through a customized installation page. Once the template is installed, users are ...
    • Downlinks using Dashboards
      Learn how to perform downlink for Class C or A devices using Analysis. Also, we will show how to send downlink data from dashboards. This approach can be used in the following cases: For devices with class C: to immediately send a downlink message to ...
