Blueprint Dashboard
Blueprint Dashboard
Blueprint is a type of Dashboard that allows users to dynamically link widgets to multiple devices. This type of dashboard is extremely useful when scaling up applications.
Concepts
Blueprint works by allowing users to change the widgets' devices in realtime inside of the Dashboard. These dynamic devices are called Blueprint Devices, and you can learn more about them in the following sections of this article.
This means that you can distribute the same Dashboard to hundreds of different TagoRun Users and each one would see their own data inside of the Dashboard.
Blueprint Devices
Blueprint Devices are dynamic devices that can be changed by the User while viewing the Dashboard. Changing these devices will reload the data for the Widgets that use them.
    • Blueprint Devices & Entities
      Blueprint Devices and Entities serve as dynamic data sources for Blueprint Dashboards. These dashboards allow you to change data sources dynamically while retaining the same widgets and configurations. By creating blueprint devices or entities, you ...
    • Dashboard Overview
      A dashboard is where you place your widgets to visualize and interact with data, all in real-time. Dashboards can also be shared with end-users that will access your application using TagoRUN. All your dashboards are listed on the sidebar of the ...
    • Dashboard icons
      You can customize the looks of your dashboard by adding icons to it. The icons are displayed on the left side of your dashboard. The colors are totally customizable, and there are more than 100 free icons available for you to use. To add an icon to ...
    • Creating Dashboard Tabs
      By using Tabs, you can divide dashboards into multiple sections and add links to them. This is a great feature to create applications where the user has to deal with some setups and data in the same dashboard, the result is something like the image ...
    • Restoring your Dashboard to a previous version
      In TagoIO Admin, each time you make changes to your dashboards and widgets, the system automatically generates a backup version of each action taken. This ensures that you can revert to a previous version of your dashboard if you encounter any issues ...
