Custom Settings is a powerful feature that enables you to create unique visualization preferences for your end-users that goes beyond TagoRUN's
default settings. After configuring your custom settings, they will appear in your end-users' Account Settings.
With this feature, you can customize preferences to fit specific needs, such as selecting preferred units for visualizing temperature, distance, and other measurements in combination with Dynamic Formulas.
How it works
To create your Custom Settings, first navigate to your Run and click on the Custom Settings tab. From there, you can configure the following fields:
1. Name: the name of the field that will be displayed for your end-users.
2. Type: determines the type of field that the user will interact with.
3. Tooltip: the text that will display when the user hovers over the field.
4. Required: if you set the field as required, the user will not be able to save without selecting a preference.
5. Field Options: allows you to specify the options that the user can select. You must define a Value to be used with Dynamic Formulas and a Label that will be displayed for your end-users. Additionally, you can set a value as Default, which will be applied to new users. At least one option must be set as the default.
Keep in mind that the Values set in the Field Options are supposed to be unique since they are used as identifiers.
After saving the options for a dropdown field, it's essential not to change the Value from Field Options. If you need to modify the Value or remove an option, you should update your users' preferences using the SDK or an Analysis.
Keep in mind that editing the options for a field will not automatically update the preferences that your users have already saved.
Once you have created your Custom Fields and deployed your updated RUN, your users can select their preferences by navigating to the Visualization Preferences tab on their Account page. Configuring your Custom settings
After setting up your Custom Fields, the next crucial step is to configure your widgets to utilize Dynamic Formulas. This feature allows you to apply formulas to your Custom Fields created through Custom Settings.
Read more about the Dynamic Formulas.
Related Articles
Run Theme
You have the freedom to personalize the look and feel of the RUN interface, allowing you to craft your application using a unique color palette that resonates with your style. To get started, access the Run module and navigate to the Theme tab. The ...
Sidebar
The sidebar on the left side of your Run application is very important for end users to navigate between dashboards. You can create buttons for quick access, and not only to open dashboards but also to open other pages or even connect a new Wi-Fi ...
Navigation bar
The navigation bar is a section of your Run portal that allows your end-user to easily navigate between pages and access their account information. The bar is located on the top of your run portal for convenient visibility, and can be customized to ...
TagoRUN Mobile App
Our TagoRUN mobile app is suitable for end-users to access the applications designed by companies and developers. It is easy to operate it and it allows a high level of customization. Download TagoRUN App from AppStore or GooglePlay. A custom mobile ...
Notifications for Users using Analysis
The Analysis is always a powerful tool when it comes to TagoIO, and that does not change for Notifications. Here you will learn how to send a notification for your TagoRun users using Analysis, how to use buttons, and how to handle user decisions ...
