Running Analysis via Action
Actions have the power to initiate scripts that run in the Analysis. This is a very powerful feature, as you can define exactly when your code will run.
For example, you can run an Analysis every time data is sent from a device, or when it meets a certain condition. Learn more about Trigger by Variable.
Another thing you could do is trigger the Action when a resource change happens, such as when a new Device is created, or when a new RunUser is registered. Learn more about Trigger by Resource.
You could also create a Schedule Action and trigger the Analysis in a constant time interval.
Setting up the Action
To run an Analysis inside of the Action, you must create your Action and set the field Type of action as Run Analysis.
Info
You can specify up to 10 Analysis that will run in parallel when the Action is triggered.
Action Contexts Variables
When an Action triggers an Analysis, it automatically adds context variables that provide information about how the Analysis was initiated. These variables can be essential for the Analysis to execute correctly and respond appropriately to the specific trigger.
Field NameDescription
_action_idThe unique identifier for the Action.
_action_typeThe category or type of Action that triggered the Analysis.
_action_stateIndicates whether the Action was locked or unlocked at the time this Analysis was run.
_device_idThe identifier of the device that triggered the Action, if triggered by a device
    • Running Analysis as External using Node.JS
      Analysis is what allows you to create powerful applications on TagoIO. When creating analysis you have to choose between running it at TagoIO or External, which means that you will run on your machine. You can choose to run the analysis on an ...
    • Creating Analysis
    • Analysis Overview
    • Parser vs. Analysis Comparison
      The Payload Parser was created to handle raw payload sent by the devices in order to extract the measured variables or execute simple operations. Analysis is much more powerful, including access to Devices and external services. Also, there is a cost ...
