Trigger by Variable
Trigger by Variable
The trigger type, Trigger by Variable allows you to execute your Actions when a variable meets certain conditions. If your device has sent data and the variables are meeting those conditions, this action will be triggered.
There are 2 (two) categories inside of this trigger type:
  1. Single device: Allows you to watch a specific device in your list. Any data that is sent by that device will be tested against your conditions to decide if this action should be triggered or not.
  2. Multiple devices: Allows you to watch multiple devices. Any data that is sent by those devices will be tested against your conditions to decide if this action should be triggered or not. For this type, you must supply the tag key and tag value of the devices you want to watch.
It's important to note that only the Single device category allows you to set Trigger Unlock conditions. To learn more about Trigger Unlock.
Trigger Conditions
After setting up the device, you should set a condition for your action to be executed. To do so, you must head over to the Trigger section.
You can set multiple conditions in an action, if at least one of them results in a match, the action will be executed.
Notice that setting up multiple conditions will execute the action only once if any of the conditions are matched. This means that if you send two variables that would trigger the action at same time, it will only trigger one action.
  1. Select a variable: Select a variable to be tested. This will be one of the variables that will be compared against the data from the device.
  2. Condition: The type of condition to test the variable. The available test conditions are:
    1. Less than: condition is true when the value of the variable is less than the value defined;
    2. Greater than: condition is true when the value of the variable is greater than the value defined;
    3. Equal to: condition is true when the value of the variable is equal to the value defined;
    4. Different from: condition is true when the value of the variable is different from the value defined;
    5. Any: condition is true whenever a new value of the variable is sent to the bucket;
    6. Between: condition is true when the new value is between a fixed value range;
  3. Value: The value to complement the condition. In the example above, the value for the condition is 15.
  4. Field type: The field type to use in the comparison. The system will force this field type when comparing the values from the device and the value defined in the condition (15). You could, for example, set the value to 0x1 and set this field to string in order to compare the number as a string.
The example above means that the action will be triggered when my_variable is less than 15.
Looking to create more complex logic statements? You can use the action to trigger an Analysis, and then manually create the custom logic inside of the code.
Trigger Unlock
Only the type Single device allows you to set Trigger Unlock conditions.
    • Trigger by MQTT Topic
      The trigger type, Trigger by Variable, allows you to execute your Action when data is sent to an MQTT topic. TagoIO has its own MQTT broker that is responsible for pushing data to clients in case something new is published in the specific topics they ...
    • Trigger Unlock
      Trigger Unlock conditions allow you to unlock your action. Before reading this article, you should read about Trigger Conditions. Each time a Trigger Condition is met, the trigger is locked if there is at least one Trigger Unlock condition. If ...
    • Trigger by Resource
      The trigger type Trigger by Resource allows you to execute your Action when a resource meets certain conditions. A resource is one of the following: Access Management Actions Analysis Device RunUser For example, you can trigger an Action when a new ...
    • Trigger by Schedule
      The trigger type Trigger by Schedule allows you to define a time interval in order to execute your Actions automatically. There are 2 (two) categories inside of this trigger type: By Interval: Allows you to specify a time interval to trigger the ...
    • Running Analysis via Action
      Actions have the power to initiate scripts that run in the Analysis. This is a very powerful feature, as you can define exactly when your code will run. For example, you can run an Analysis every time data is sent from a device, or when it meets a ...
            Future and past Webinars
