Trigger by Schedule
Trigger by Schedule
The trigger type Trigger by Schedule allows you to define a time interval in order to execute your Actions automatically.
There are 2 (two) categories inside of this trigger type:
  1. By Interval: Allows you to specify a time interval to trigger the Action automatically. You can choose the time interval in the right side, the minimum time allowed is 1 minute.
  2. By Date: Allows you to specify date to trigger the Action. For example, you can choose to run it at the second Wednesday of each month.
Customizing By Date
If you pick the By Date type, you can also choose to customize it in either a basic or advanced way.
Basic customization allows you to customize the date through interface fields, while Advanced customization allows you to write a cron to define the date.
To understand more about the Advanced customization, head over to this article.
1. Basic customization
Basic customization allows you to configure a precise date with the help of an interface.
  1. Repeat Every: Allows you to specify the interval between executions. It allows 3 time units:
    • Day
    • Week
    • Month
  2. Repeat at: Allows you to specify the time when your Action will be triggered.
  3. Repeat on: Allows you to specify the weekdays when your Action will be triggered.
  4. Timezone: Allows you to set the timezone of the Action. By default the timezone will always be the one defined in your Account.
  5. Customization: Allows you to change between Basic and Advanced customization. The basic mode is the default, but you can choose to use the advanced mode. Click here to learn more about Advanced customization.
  6. Explanation: If you are feeling confused as to when your action will be triggered, check out this field. It tells you exactly when the Action will be executed.
2. Advanced customization
Advanced customization gives you more freedom to trigger your Action by using cron.
To understand more about the Advanced customization and cron logic, head over to this article.
    • Trigger Unlock
      Trigger Unlock conditions allow you to unlock your action. Before reading this article, you should read about Trigger Conditions. Each time a Trigger Condition is met, the trigger is locked if there is at least one Trigger Unlock condition. If ...
    • Trigger by MQTT Topic
      The trigger type, Trigger by Variable, allows you to execute your Action when data is sent to an MQTT topic. TagoIO has its own MQTT broker that is responsible for pushing data to clients in case something new is published in the specific topics they ...
    • Trigger by Resource
      The trigger type Trigger by Resource allows you to execute your Action when a resource meets certain conditions. A resource is one of the following: Access Management Actions Analysis Device RunUser For example, you can trigger an Action when a new ...
    • Trigger by Variable
      The trigger type, Trigger by Variable allows you to execute your Actions when a variable meets certain conditions. If your device has sent data and the variables are meeting those conditions, this action will be triggered. There are 2 ...
    • Running Analysis via Action
      Actions have the power to initiate scripts that run in the Analysis. This is a very powerful feature, as you can define exactly when your code will run. For example, you can run an Analysis every time data is sent from a device, or when it meets a ...
