Custom Domain & Whitelabel
Adding the Custom Domain & Whitelabel add-on will unlock the following configurations in the Run module.
- Ability to choose a custom URL for the application
- For example, if your current company domain is mycompany.com, you can add your Run using portal.mycompay.com
- Custom E-mail domain
- E-mails sent to users will be originated from your domain, and not from @tago.io
- Removal of references to the TagoIO brand
The Custom Domain & Whitelabel add-on allows a higher level of brand engagement with your end-users.
You can select the add-on in your Profile.
Related Articles
Add-ons Overview
On top of the fundamental IoT services provided to run your applications, great add-on modules are also available to customize your application using TagoRUN. Add-ons are applied separately to each of your Profiles. In your account, go to Profiles, ...
Account Plans
TagoIO offers three Account plans that you can choose from to take advantage of the best tools for your application. Select your plan on the My Billing page. A certain limit of services are already included in your Plan. For more details about the ...
Custom Widget
Custom widgets allow developers to incorporate powerful content in their own widget for their dashboards. Creating your own The sky's the limit when using this widget. You can build your widget using Angular, React, Vue.js, or even plain old ...
Custom mobile app
Add the Custom mobile app add-on to keep the deployment of your own mobile app. Your mobile app will be completely white-label, so that when your clients locate and download it from the App Store & Google Play it’ll be a professional looking ...
Custom Widget Parameters
Parameters allow you to send a list of keys and values to your custom widget. One use of these parameters is to change the way your code behaves. You can have two widgets pointing to the same link, but exhibiting different behaviors. Each parameter ...
