API Overview
API Overview
It is easy to connect devices, data sources, or third-party APPs to your account using TagoIO Application Programming Interface (API).
We have a comprehensive set of APIs that gives you full control to manage your accounts, data, devices, dashboards, and scripts. You can use the resources available in the Admin page to create, delete, or edit your accounts and dashboards; however, you can do all the same things directly using API.
Acces the API documentation.
We follow RESTful principles. Before checking the API documentation, there are some details you should know.
Looking for our SDK ?
All responses from TagoIO API have a pattern, and you will always receive something like this:
// For success:
        'status': true,
        'result': [...]
// For warning:
        'status': true,
        'result': {...},
        'message': 'Warning message'
// For failed:
        'status': false,
        'message': 'Error message'
status: it is always boolean. If your request is successful the response will be true, otherwise it will be false.
result: can be any object type (that is dynamic object), depends what api endpoint you called for.
message: it is a message from the server. Usually it is used when has any error or warning.
Security
TagoIO takes the necessary steps to protect your data in the database and also during the communication between our server and your devices.
All communication between the devices, your application, and TagoIO server is performed through Hypertext Transfer Protocol Secure (HTTPS) to avoid the man-in-the-middle and wiretapping attacks.
Although the communication can also be performed with HTTP, TagoIO doesn’t recommend it. By doing so will eliminate the security of authentication and encryption provided by SSL/TLS protocols part of HTTPS. Just in case you really need to use HTTP without SSL, all you have to do is to add _ssl=falseon the header or url query string.
Secret tokens for account and devices are generated by TagoIO system and can be individually managed by the user. Different levels of access can be granted to different users or devices.
The URL that your device should connect is https://api.tago.io/data through Port 443.
Tokens
There are four type of tokens: Account-TokenDevice-TokenAnalysis-Token and Middleware-Token.
You are able to generate all tokens from TagoIO admin or directly using API. The type of token and its expiration can also be defined. Just add them in the header of your the http request.
HEADER KEYHEADER VALUE
Account-TokenOnly Account Token
Device-TokenOnly Device Token
Analysis-TokenOnly Analysis Token
Middleware-TokenOnly Middleware Token
Authentication Any Token (Account or Device)
Check the usage policy based on number of requests per a certain period.
Regional endpoints
When making a request to the TagoIO API, you must also specify the appropriate regional endpoint. Check out the available regions here: API documentation
https://api.<region>.tago.io/
    • RESTful API
      We provide a powerful set of Restful API documentation that's used by Analysis behind the scenes to perform all sorts of requests to TagoIO, such as but not limited to: Creating, deleting and editing devices Creating, deleting and editing ...
    • Connector Overview
      Connectors enable you to create a device with built-in behaviors that allow it to communicate with a Network very easily. They also help you automate and scale your devices, once you create a device using a connector, that device will also run the ...
    • Analysis Overview
    • Services Overview
      TagoIO offers a broad range of services that can be allocated the way your applications needs it to be. By provisioning the services that each Profile will use throughout the month, you will know exactly how much you will be charged. You can ...
    • Dashboard Overview
      A dashboard is where you place your widgets to visualize and interact with data, all in real-time. Dashboards can also be shared with end-users that will access your application using TagoRUN. All your dashboards are listed on the sidebar of the ...
