Add-ons Overview
Add-ons Overview
On top of the fundamental IoT services provided to run your applications,  great add-on modules are also available to customize your application using TagoRUN.
Add-ons are applied separately to each of your Profiles.
In your account, go to Profiles & Teams, select a profile, and add one or more of the add-ons available for you.
Currently, these are the add-ons available:
    • Connector Overview
      Connectors enable you to create a device with built-in behaviors that allow it to communicate with a Network very easily. They also help you automate and scale your devices, once you create a device using a connector, that device will also run the ...
    • Dashboard Overview
      A dashboard is where you place your widgets to visualize and interact with data, all in real-time. Dashboards can also be shared with end-users that will access your application using TagoRUN. All your dashboards are listed on the sidebar of the ...
    • Analysis Overview
      Analysis is a powerful feature that experts and developers can use to implement scripts to analyze and manipulate data from any device in real-time. The scripts that run at TagoIO are programmed with the Node.js TagoIO's SDK. Get more instructions on ...
    • Widgets Overview
      Dashboards are composed by widgets that can display and collect data from users. TagoIO provides a variety of widgets to handle your data in real time. The available options cover from simple dials to tables, maps, videos, and even forms that you can ...
    • API Overview
      It is easy to connect devices, data sources, or third-party APPs to your account using TagoIO Application Programming Interface (API). We have a comprehensive set of APIs that gives you full control to manage your accounts, data, devices, dashboards, ...
