Data Output Service
Data Output Service
One transaction of Data Output is counted for each register read from a data bucket. Learn more about Getting Data.
You need to define the Data Output limit per month for each Profile where your applications are running.
Here is one example: a device reads one variable resulting in a response of 100 registers at every 10 minutes (100 temperature data points), the operations will result in 100 * 6 = 600 transactions per hour, which can then be converted by multiplying by 720 to result in 600 * 720 = 432,000 transactions/mo.
If the limit is exceeded, any attempt to read data (GET) will be denied for the rest of the month.
Accessing data from the dashboards, including when it's downloaded in .csv format from the widgets, does not count towards the general Data Output limit. Instead, a separate data output limit, specifically for dashboards, is consumed. For more information, please refer to our documentation on Data Output for Dashboards.
The system will also count data output when using the function 'Export Data' from the bucket.
Request limits are applied to a wide range of interactions within the platform, including activities such as reading and exporting data. Read more about our Rate Limits.
    • Data Output for dashboards
      In TagoIO, each time someone accesses data from the Dashboards using TagoIO Admin or TagoRUN, a data output is counted for each variable displayed. For instance, when an end-user loads a dashboard that displays 3,000 registers, this same number will ...
    • Data Input Service
      Each time a device sends data to TagoIO, the system will count 1 Data Input Transaction for each variable. These data input transactions are counted against the Profile where your devices are located. You need to estimate the maximum number of ...
    • Data Export
      The Export Data feature enables you to efficiently extract variables from your bucket. This function is accessible within the Admin panel, specifically in the Bucket Module . To use it, select a bucket and navigate to the ' Variables' tab. On this ...
    • PDF Service Generator
      Learn how to create PDF documents using the TagoIO service generator. Simply make an HTTP request to our PDF service, and the response will be a base64. The base64 response can be sent by email using Analysis or it may be saved in our Files. POST ...
    • Sigfox using 'Advanced Data'
      The Advanced Data option allows you to receive additional information like SNR, RSSI, STATION, and others.  The type of information available will depend on your Data Plan contracted with Sigfox. On the Sigfox Backend Portal, create a callback type ...
