HEADERS:
Authorization: Your-Device-Token
GET - https://api.tago.io/data
QUERYSTRINGS:
KEY | TYPE | DESCRIPTION |
variable | string || array | Get variables |
query | string | pre-defined by Tago |
qty | string | Maximum number of data to be returned. |
start_date | string | Start date (E.g 1 day or ISO String) |
end_date | string | End date (E.g 1 day or ISO String) |
detail | bool | Add more JSON fields on result fields |
Response - Below is the data returned without any parameters. https://api.tago.io/data
"status" : true,
"result": [
"id": "547e42847dbf3af122c02582",
"location": {
"coordinates": [
41.878876,
-87.635915
"type": "Point"
"time": "2014-12-02T22:51:48.005Z",
"variable": "location"
"id": "547e353d7dbf3af122c0257d",
"time": "2014-12-02T21:55:09.301Z",
"unit": "%",
"value": 32,
"variable": "fuel_level"
"id": "547e41f97dbf3af122c02580",
"time": "2014-12-02T22:49:29.777Z",
"unit": "psi",
"value": 25,
"variable": "oil_pressure"
variable
- using the parameter variable you define the variable that should be returned with the GET method.
For example, to get data with the variable = temperature, use: https://api.tago.io/data?variable=temperature
Also, you can use an array to get more variables: https://api.tago.io/data?variable[]=temperature&variable[]=pressure
query
- the query parameter returns some predefined functions to help you to obtain certain processed data. Note that you can not use two queries concurrently.
last_item
- It will return the last information from the data based in the 'time'.
For example: https://api.tago.io/data?variable=temperature&query=last_item
last_value
- It will return the last information from the data based in the 'time'. Only the data containing ‘value’ information will be returned.
For example: https://api.tago.io/data?variable=temperature&query=last_value
last_location
- It will return the last information from the data based in the 'time'. Only the data containing ‘location’ information will be returned.
For example: https://api.tago.io/data?variable=temperature&query=last_location
qty
- Limit the number of results that will be returned from a query. The default value is 15.
For example: https://api.tago.io/data?variable=temperature&qty=99
It will return the last 99 registers from temperature.
start_date
- Define the start time for the data search. Only the data containing ‘time’ information newer than start_date will be returned.
end_date
- Define the end time for the data search. Only the data containing ‘time’ information older than end_date will be returned.
For example: https://api.tago.io/data?variable=temperature&start_date=2014-12-25&end_date=2014-12-26
It will return the data from the variable temperature between the start_date & end_date. The default it will return the last 15 items from the variable.
If your interval has more than 15 items, you need to add the attribute qty
For example: https://api.tago.io/data?variable=temperature&start_date=2014-12-25&end_date=2014-12-26&qty=999
Start/End date parameters accept different formats, which include selection based on relative time (e.g. to get data from the last 1 hour). Below are some examples:
DATE FORMATS
“2014-12-25”
“2014-12-25 23:33:22”
“Thu Dec 25 2014 23:33:22 GMT+1300 (NZDT)”
“2014-12-25T23:33:22.000Z”
“1 day”
“1 month”
“1 year”
