Gauge Overview
Gauge Overview
Gauge contains a collection of metric widgets. You can choose among several types of Gauges that will present the last value of a variable in different formats.
Dial
Dials are one of the simplest and more useful widgets. They make it easy to visualize the values relative to a defined range (maximum and minimum limits).
Learn more about the Dial Gauge.
Angular
Angular allows you to show your variable in an angular gauge meter.
To learn more about the Angular Gauge.
Solid
Solid gauges display your variable in a solid gauge meter.
To learn more about the Solid Gauge.
Clock
Clock gauges allow you to visualize the time in a certain timezone. You can see the selected timezone, weekday, hour, minutes and seconds.
To learn more about the Clock Gauge.
VU Meter
VU Meter gauges show the variable in a velocimeter gauge.
To learn more about the VU Meter Gauge.
    • Gauge - Data Range & Format
      Data Range & Format is the place where you can define the format and also the range of the data inside the gauge. Range Limits In the Range limits section you can set the minimum and maximum value displayed in the gauge. There are two different types ...
    • Connector Overview
      Connectors enable you to create a device with built-in behaviors that allow it to communicate with a Network very easily. They also help you automate and scale your devices, once you create a device using a connector, that device will also run the ...
    • Dashboard Overview
      A dashboard is where you place your widgets to visualize and interact with data, all in real-time. Dashboards can also be shared with end-users that will access your application using TagoRUN. All your dashboards are listed on the sidebar of the ...
    • Analysis Overview
    • Services Overview
      TagoIO offers a broad range of services that can be allocated the way your applications needs it to be. By provisioning the services that each Profile will use throughout the month, you will know exactly how much you will be charged. You can ...
