Dial Widget
Dial Widget
Dials are one of the simplest and most useful widgets. They make it easy to visualize the values relative to a defined range (with maximum and minimum limits).
This widget also accepts features like metadata, that can be set in your variable data.
Creating your own
To add it to your dashboard, choose the Dial widget from the list and customize it to your preference. You can edit it by using the options located on the right side of the widget.
1. 'Data From' Field
    • Widget Cache system
    • Input Form Widget
      The Input form allows users to submit values to variables through a form. Editing the form The Input form is a very dynamic widget. You can customize its colors, layout, text, and even icons. To edit a specific section of this widget, you must hover ...
    • Custom Widget
    • Note Widget
    • Compose Widget
