Angular Widget
Angular Widget
Angular gauges allow you to display your variable in an angular gauge meter.
This widget also accepts features like metadata, that can be set in your variable data.
Creating your own
To add it to your dashboard, choose the Angular widget from the list and customize it to your preference. You can edit it by using the options located on the right side of the widget.
1. 'Data From' Field
    • Widget Cache system
    • Custom Widget
    • Note Widget
    • Compose Widget
    • Map Widget
