Solid Widget
Solid Widget
Solid gauges allow you to display your variable in a solid gauge meter.
This widget also accepts features like metadata, that can be set in your variable data.
Creating your own
To add it to your dashboard, choose the Solid widget from the list and customize it to your preference. You can edit it by using the options located on the right side of the widget.
1. 'Data From' Field
    • Widget Cache system
    • ECharts Custom Widget Tutorial
      In this tutorial, we will guide you through the process of creating a Ring Gauge custom widget, which enables you to display multiple variables simultaneously in a interesting format. To achieve this, we will leverage the ECharts library, a robust ...
    • Custom Widget
    • Note Widget
    • Compose Widget
