Sens'it with Sigfox
Sens'it with Sigfox
TagoIO is fully integrated with Sens'it v2 and v3 devices by providing the perfect integration with Sigfox backend and parsing the data by extracting the measured variables in real-time. Sens'it + Sigfox + TagoIO    Connectivity DiagramAll data sent by your device will be readily available to be displayed in widgets or processed in your Analysis.
First you need to activate your Sens'it as a devkit. As a developer, you can request access to the Sigfox Cloud from the Sigfox Buy website - simply follow the instructions to activate the devkit. Once activated, you can enjoy your devkit connectivity.
Second, add the device at TagoIO. Go to Devices, click on 'Add Devices', and filter network by Sigfox to pick your device from the list (v2 or v3).
Then, just follow the directions to integrate your Sens'it with TagoIO and start to build your own application in minutes.
If you have questions about how to configure your account for Sigfox and TagoIO, read more about Sigfox.
Now, click on the new dashboard created (left menu), and associate it with the device that you just added.
Turn your Sens'it device on, and wait for the data to arrive and hit your data bucket. Every time the device sends data, the parser will be executed, the extracted data sent to the bucket, and it will be ready to be shown in the dashboards.
You can start editing the installed dashboard.
Dashboard automatically installed with the device.
If you are using Sens'it v2, you may want to edit the parse function in your device to extract variable from more modes for the V2. Check the complete payload documentation.
Also, you can create notifications and more advanced scripts as needed.
Enjoy your Sens'it device with TagoIO!
    • Sigfox
      Sigfox is a relatively low-cost wireless network technology that requires low power to connect, and that is implemented by lost cost hardware modules. This tutorial provides a step-by-step guide to integrate Sigfox with the TagoIO Platform. By ...
    • Sigfox - Downlink
      TagoIO is ready to receive data from and send data to Sigfox devices. The Downlink is used to send data back to the module every time it checks in – the data to be sent down should be ready prior to the check-in. This tutorial explains how to setup a ...
    • Thinxtra Xkit for Sigfox
      This tutorial explains how to connect the Xkit from Thinxtra with TagoIO. This Sigfox board can be connected to a PC, Mac, Arduino, Raspberry PI, and other platforms. Here is a diagram of Xkit board's pinout, you can click here for more details. Xkit ...
    • Adeunis with Sigfox
      TagoIO supports most Adeunis devices by providing the perfect integration with Sigfox backend. Also, it parses the data by extracting the measured variables in real-time. Adeunis + Sigfox + TagoIO diagram All data sent by your device will be readily ...
    • Sigfox using 'Advanced Data'
      The Advanced Data option allows you to receive additional information like SNR, RSSI, STATION, and others.  The type of information available will depend on your Data Plan contracted with Sigfox. On the Sigfox Backend Portal, create a callback type ...
