Usage Policy
Usage Policy
When executing API requests to TagoIO by posting (data input) or to getting (data output) data, your account may face a limit policy based on the limits defined by you in the My Billing settings.
The limits are based on the number of transactions defined for a period of time (hour or minute). Also, a higher limit is applied to all accounts to prevent attacks to our servers, such as DDOS, while offering a way to limit the usage for your applications.
Check our comprehensive documentation on Rate Limits.
TagoIO limits the access of Account-Token and Device-Token to the transactions limits per hour set in your account.
Other services like data storage, SMS, email, and Analysis are also limited according to your plan settings. Learn more about TagoIO Services.
    • Refund Policy
      If you have forgotten to cancel your plan or have decided to cancel it, you may be eligible to receive a refund. TagoIO offers refunds in certain situations. In order to initiate the process, if you are entitled to the refund, follow the steps below: ...
    • Trigger by Usage Alert
      The "Trigger by Usage Alert" is a feature that enables you to execute an Action when a specific service or resource meets predefined conditions. Below, you will find a list of Resources and Services that can be used to trigger your action. Resources ...
    • API Overview
      It is easy to connect devices, data sources, or third-party APPs to your account using TagoIO Application Programming Interface (API). We have a comprehensive set of APIs that gives you full control to manage your accounts, data, devices, dashboards, ...
    • Network Integration
      Your devices can always connect directly with TagoIO API using HTTPS or MQTT protocol. But, you can also connect them using different protocols to databases and web services by using one of this methods: Create a script that initiate access to ...
    • Devices
      Device is the link between your external things and the data in your account. To allow anything to send or receive data from TagoIO, you need to create a device. The communication between external devices and TagoIO is done via HTTP or MQTT methods ...
