TagoIO offers a broad range of services that can be allocated the way your applications needs it to be. By provisioning the services that each Profile will use throughout the month, you will know exactly how much you will be charged.
You can visualize the limits and the usage history for each service in the Usage Statistics tab, located under the Profiles session of your TagoIO account. If you have more than 1 profile, you will need to allocate the resources for each profile.
Currently, this is the list of services that you can select for your account. Some of them are reset monthly.
Service
Unit
Usage counted
Definition
Data Input |
Variable
Monthly
Data Output
Variable
Monthly
Data Storage
Variable
Maximum at any time
Each variable stored in a Device |
File Storage
Size (MB)
Maximum at any time
Total aggregate size of all files stored on the 'Files' module
Analysis for Scripts
Execution time
Monthly
Total script runtime executed by the Analysis module (minimum 1s)
Push Notifications
Message
Monthly
Messages sent out
End user (RUN user)
User
Maximum at any time
End users registered in your RUN applications
More information with examples and FAQ can be found at our Pricing Page.
