Related Articles
API Overview
It is easy to connect devices, data sources, or third-party APPs to your account using TagoIO Application Programming Interface (API). We have a comprehensive set of APIs that gives you full control to manage your accounts, data, devices, dashboards, ...
machineQ LoRaWAN™
This tutorial provides a step-by-step guide to integrate machineQ LoRaWAN with the TagoIO Platform. By following these instructions, you will enable uplink and downlink operations, allowing data exchange between your LoRaWAN devices and the TagoIO ...
Map Widget
Sending Data
When making a request to the TagoIO API, you must also specify the appropriate regional endpoint. Check out the available regions here: API documentation A device can send data to TagoIO by using the POST method. POST ...
Tags System
Tags are a flexible and powerful way for organizing and labeling your assets within TagoIO, allowing you manage access and identify key components such as Devices, Actions, Analysis, Dashboards, Users & Access rules. Operating like key-value pairs, ...
