Related Articles
Running Analysis as External using Node.JS
Analysis is what allows you to create powerful applications on TagoIO. When creating analysis you have to choose between running it at TagoIO or External, which means that you will run on your machine. You can choose to run the analysis on an ...
Analysis Overview
Python SDK
You can access our SDK documentation on: https://py.sdk.tago.io/ Installation pip install tagoio-sdk Quick Start from tagoio_sdk import Account account = Account({"token": "your-token"}) devices = account.devices.list() Remote Imports in Analysis ...
Creating Keypad Widgets
This article will demonstrate how to create a Keypad Widget using the TagoIO Node.js SDK. In order for you to create keypad widgets, this is the structure that you will need to send to the account.dashboards.widgets.create method. { "analysis_run": ...
Creating Analysis
