Python SDK
Python SDK
You can access our SDK documentation on:
Installation
  1. pip install tagoio-sdk
Quick Start
  1. from tagoio_sdk import Account
  2. account = Account({"token": "your-token"})
  3. devices = account.devices.list()
Remote Imports in Analysis
Python Analyses supports remote imports. Just import packages directly in your script and they'll be installed at runtime:
  1. from tagoio_sdk import Analysis
  2. from pandas import DataFrame
  3. import requests
Info
When executing requests to TagoIO, you will have a limit on the number of requests that can be made during a certain time period. Read more about our Rate Limits.
    • Analysis Overview
    • Node.js SDK
      You can access our SDK documentation on: https://js.sdk.tago.io If you are looking for documentation for old version (9.x.x) you access it on: https://tago-sdk-js-documentation.rtfd.io/ The old SDK will be discontinued at 2030. When executing ...
    • Creating Analysis
    • Beagle Bone Black
      This simple tutorial using the Beagle Bone Black - BBB board will show you some principles to integrate your solution with Tago. More than just connect the BBB to the cloud, you will learn how to easily reuse this code into your own application ...
    • Raspberry Pi
      Visit this tutorial from our Community to learn how to communicate a Raspberry PI board with TagoIO using our SDK or the MQTT protocol.  More tutorials like this are available in our Forum inside our Community.
