Creating a Policy
Creating a Policy
You can create individual policies to securely grant access to certain resources in your account for pre-defined targets.
You create Targets (e.g. users) and determine which type of resource Permissions (e.g. dashboards) they will have.
You can manually configure a policy by creating a Policy under the Access module.
    • Defining Targets
      You should define Targets in each policy that are used inside the Access Management module (AM). Targets can be users or things (scripts). Targets are to whom or to what you are giving the permissions. Currently, you can select Run Users and Analysis ...
    • End-User Agreements
      End-User Agreements is a feature designed to help you manage and track legal agreements or terms of service that users must accept before accessing the platform. This feature ensures compliance and provides a transparent method for maintaining ...
    • Import & Export for Dictionary
      The Dictionary also provides a quick and easy way to import and export a Dictionary’s key and value pairs via the two buttons at the top of a Dictionary page. All data in a Dictionary can be exported into a CSV or JSON file, and that file can be used ...
    • Security and Protection for RUN users
      With TagoRUN, you can provide actions and methods to increase your application's security and protection for your Run users, as well as make your application comply with the main laws regarding data privacy and security by providing your end-user ...
