Tables
Tables
Table widgets present your data in a tabular way. You can also allow users to change values on the cells, delete rows, and more.
The following table widgets are available:
Static Table
It is one of the special kinds of widgets that unlike the others, you won’t find the traditional variable selector. In this type, you specify a static amount of rows and columns. This option is really great if you're not looking to display the history of previous variables values. Learn more about Static Table.
Dynamic Table
Dynamic tables are tables that are populated dynamically as your data arrive while keeping the history of the previous data in each row. The configuration is very easy, all you have to do is pick your variables. Learn more about Dynamic Table.
Device List
Device List widget is a table that dynamically populates with information about your devices, such as names, tags, configuration parameters, and IDs. Learn more about Device List Widget.
User List
The User List widget is a table that dynamically populates with information about your users, such as names, tags, email, and IDs. Learn more about User List Widget.
Entity Table
The Entity Table widget enables you to display data in a tabular format using fields from your Entities. Unlike the Static and Dynamic Table widgets, it does not utilize data from Devices. Learn more about Entity Table Widget.
    • Widgets Overview
      Dashboards are composed by widgets that can display and collect data from users. TagoIO provides a variety of widgets to handle your data in real time. The available options cover from simple dials to tables, maps, videos, and even forms that you can ...
    • Markdown Guide
      Emphasis **bold** *italics* ~~strikethrough~~ Headers # Big header ## Medium header ### Small header #### Tiny header Lists * Generic list item * Generic list item * Generic list item 1. Numbered list item 2. Numbered list item 3. Numbered list item ...
    • Dynamic Table Widget
      Dynamic tables are tables that dynamically populate as your data arrive while keeping the history of the previous data in each row. Editing the dynamic table It is possible to customize widget color, apply a formula to columns, show time column, show ...
    • Static Table Widget
      Static tables are tables where each cell represents a different piece of information, and it can either be fixed text or data from a variable. Editing the static table It is possible to customize widget color, apply a formula to a cell, edit options, ...
    • Queclink GPS
      Queclink GPS can be integrated with TagoIO through the middleware that translates the devices TCP/IP protocol. The middleware allows uplink communication between the device and TagoIO while parsing the messages in order to extract commands and ...
