Dynamic Table Widget
Dynamic tables are tables that dynamically populate as your data arrive while keeping the history of the previous data in each row.
Editing the dynamic table
It is possible to customize widget color, apply a formula to columns, show time column, show control column, and more.
This widget also accepts features like metadata and series, that can be set in your variable data.
To edit a specific section of this widget, you must hover over the desired element and click it. Promptly, a new page will appear on the right side with all the editable options for the selected element.
1. 'Data From' Field
Each column has the field Data From, this field allows you to set the device and variable that will be used in this widget.
When using a Blueprint dashboard, the field Variable will not list variables to be picked because it doesn't know the devices linked to your Blueprint Device
2.  Grouping data
The dynamic table lets you group related data from multiple columns in the same row by either series or time.
The variable's data that has the same time will be grouped in the same row.
3. Data visualization
The dynamic table offers the possibility of customizing each column's data visualization. It is possible to apply Formula, make cell colors change based on conditions, use icons to represent your data, and more.
The color cell can be sent by the variable metadata.
4. Filtering Data
Filtering data can be done by each column or by the whole table. It's customizable on the Widget's edit screen.
5. Editing data
You can allow users to modify a variable's value inside of a table by enabling the edit option located inside the column's configuration.
It is possible to set some columns as required when editing the row value
Dynamic Table offers a bunch of field types to indicate what kind of value can be submitted in the input once the user modifies it. These types are Text, Password, Number, Dropdown, Dropdown Multiple, Address, Entities and Device (configured by tags).
These field types have the same behavior as the Form's fields.
    • Entity Table Widget
      The Entity Table widget enables you to display data in a tabular format using fields from your Entities. Unlike the Static and Dynamic Table widgets, it does not utilize data from Devices. This widget lets you incorporate data from one or more ...
    • Static Table Widget
      Static tables are tables where each cell represents a different piece of information, and it can either be fixed text or data from a variable. Editing the static table It is possible to customize widget color, apply a formula to a cell, edit options, ...
    • Creating Dynamic Dropdown selection using Forms
      Dynamic Dropdown allows users to create dynamic items selection on a dropdown list like the image below The items from a Dynamic Dropdown come from a variable, this means that you can change the values dynamically, developers can create any kind of ...
    • User List Widget
      The User List widget is a table that dynamically populates with information about your users, such as names, tags, email, and IDs. 1. Editing the user list It works as a dynamic table, as you can customize its colors, columns, and filter which user ...
    • Device List Widget
      The Device List widget is a table that dynamically populates with information about your devices, such as names, tags, configuration parameters, and IDs. It can't access devices' data, however. 1. Editing the device list It works as a dynamic table, ...
