Signup Fields
Signup Fields
Inside of your Sign up page, you can add customized fields for the user on top of the required fields of the form. The Field name will be copied into the User tag key, while the value input by the user during the sign up will be copied to the User tag value.
Signup field
Tag created for the User
Field name
Tag key
Input from user
Tag value
Customization
To create customized fields, you must enter 4 pieces of information.
  • Field name: This will be the tag key (see the table above).
  • Label above the field: This is a text to guide the user, instructing them on what should be entered into this field.
  • Type: There are 3 (three) types of customized fields you can use.
    • Text: The field will be a text type, the user will be able to write anything in this field;
    • Number: The user will only be able to enter numbers in this field;
    • Hidden: The user won't be able to see the field. In this case, the tag will be created automatically with the key of the Field name and the value from the Field Placeholder.
  • Required: Indicates if this field will be required by the user or not. If you set a field to required, the user will be obligated to write something in it before signing up.
Hidden fields are not affected by the required option.
    • User Management
      You can visualize and control all users that sign up in your application under the User Management module. When you create and deploy your solution using TagoRun, all users that sign up will be listed in this area. You can grant or remove access, ...
    • Run Theme
      You can customize the appearance of RUN and build up your application with your own color palette. 1. Signup page On the Signup page, you can modify colors, background, and the logo that is displayed. It is also possible to have the background as an ...
    • TagoRun
      The Run module allows you to create and deploy your solution using a customized logo, colors, URL, sign up page, e-mail messages, and more. Run works synchronized with the Access and User management modules. When you configure and deploy your ...
    • Branding and Deploying Applications
      Use the Run module to deploy your own IoT Platform for your end-users. The options available in your RUN will depend on your current plan and the add-ons selected. Even the Free plan offers a great level of customization. 1. Deploying Your own ...
    • Custom Settings
      Custom Settings is a powerful feature that enables you to create unique visualization preferences for your end-users that goes beyond TagoRUN's default settings. After configuring your custom settings, they will appear in your end-users' Account ...
            Future and past Webinars
