Files
Files
You and your IoT devices can send and receive files such as images, csv, txt and many other file formats, and all of these files can be stored and accessed at TagoIO.
Overview
Files storage is commonly used to send and receive files from devices, store data that is generated by your devices, store images to be displayed on different widgets, store files to be attached to emails, or whatever other need you might have with storing files and getting private or public access to those files.
To use the files via Admin, go to Files in the left menu, and from there you can see and manage all the files and folders that are stored on your account. You can also upload more files from there.
Developers can use our SDK to: store and manage files using their applications, upload files from devices, and more.
Features
There are several features available on the Files page. For example, you can drag-and-drop files onto the page in order to upload them to the current folder; you can also select multiple files by using the Shift key or the Ctrl key while clicking on the desired files.
You may want to perform actions in your existing files; to find everything you can do, simply right-click one of your files, and then choose an option from the dropdown menu.
You can also just select a row and the right-side panel will show information on the selected files and folders.
    • Uploading Files
      To upload a file using the admin platform, go to Files and click on  on the top right corner of the page. By default, all files will be uploaded with Public access. This means that you can copy the file's link to easily share it with someone. ...
    • File storage service
      You can use our Files module to store any type of files for reports, videos, logos, background images, and more. The File service is measured by the overall size of all files stored in your profiles. If any of your profile reaches the limit of size ...
    • Map Layer GIS
      Display geometries, boundaries, areas, roads, pipelines, and more with the Map widget layer GIS. Each layer is defined by GeoJSON files (.geojson, .json, .zip), which you can upload and manage, either statically or dynamically. Shapefiles are also ...
    • Device data management
      The device page provides tools for visualizing, filtering, editing, importing and exporting variables, facilitating the management of data received by your device. You can access these tools by navigating to the Device module, selecting a device, and ...
    • Chunk Management
      The Chunk Management feature is a powerful tool that allows you to easily manage the data of your Immutable devices, either to create backups or delete information. By accessing the Device module and selecting a Device Data Optimized (Immutable) ...
