TagoIO supports most Adeunis devices by providing the perfect integration with Sigfox backend. Also, it parses the data by extracting the measured variables in real-time. Adeunis + Sigfox + TagoIO diagram
All data sent by your device will be readily available to be displayed in widgets and processed in your Analysis.
You can check if a parser script was added to your device under the tab 'Payload Parser'.
To add a device, just go to Devices, click on 'Add Devices', and filter network by Sigfox to pick your specific device from the list.
Device type selection for Adeunis Sigfox
Then, just follow the directions to integrate your Adeunis with TagoIO and start to build your own application in minutes.
If you have questions about how to configure your account for Sigfox and TagoIO, read the article about SigFox.
Now, just turn your Adeunis device on, and wait for the data to hit your data bucket. Every time the device sends data, the parser will be executed, the extracted data sent to the bucket, and it will be ready to be shown in the dashboards.
You can start to build your dashboards immediately.
Also, you can create notifications and more advanced scripts as needed.
Enjoy your Adeunis device with TagoIO!
