End-Users service
End-Users service
Each end-user that is added in the User Management list is counted as an end-user.
End-users, also called RUN-users, can be automatically added when they sign up in your RUN application.
Alert
If any of your profile reaches the limit of end-users allocated to it, the system will block the addition of new users.
Increase the number of end-users allowed in your application by Allocating Resources to profiles.
More information about pricing and FAQ can be found on our Pricing Page.
    • Notification Service
      Each time a push notification message is sent by an Action or Analysis function, it is counted as one Notification unit sent. The service limit defined inside each Profile determines the maximum number of Notifications that can be sent during a ...
    • SMS Service
      Each time an SMS message is successfully sent by an Action or Analysis function, it is counted as one SMS unit sent. The service limit defined inside each Profile determines the maximum number of SMS that can be sent during a one month period (based ...
    • File storage service
      You can use our Files module to store any type of files for reports, videos, logos, background images, and more. The File service is measured by the overall size of all files stored in your profiles. If any of your profile reaches the limit of size ...
    • PDF Service Generator
      Learn how to create PDF documents using the TagoIO service generator. Simply make an HTTP request to our PDF service, and the response will be a base64. The base64 response can be sent by email using Analysis or it may be saved in our Files. You can ...
    • E-mail Service
      Each time an Email is successfully sent by the Action or Analysis function, it is counted as one unit sent. This limit will define the maximum number of Emails that can be sent from that Profile during a one month period. Emails not used in a billing ...
