Compose Widget
Compose Widget
The compose widget allows you to add pins to different images and videos. You can manipulate the colors, values, and icons for each pin.
This widget also accepts features like metadata and series, that can be set in your variable data.
Creating your own
To add it to your dashboard, choose the Compose widget from the list and customize it to your preference. You can edit it by using the options located on the right side of the widget.
1. 'Data From' Field
This widget requires two types of variables, a group of variable to get the pin's data from, another to get the layer.
Click on the cog icon to edit specific options for this variable, such as formula, color, and more. Click on the close icon to remove this variable from the widget's data.
2. Background
There are four types of backgrounds: it can be an image, a Youtube video, a Vimeo video, or a generic video. You can change or customize it through the widget edit screen.
You can use TagoIO's File system to store the image or video, and cache the public URL.
You can also customize the aspect ratio of the media, and resize properties as Fill, Contain or Cover.
3. Pins position
To position the pin you need to set an x and y coordinate for your variable data. These numbers represent the x and position of the variable, with the coordinates (0,0) in the top left corner of the given image and coordinates (1,1) in the bottom right corner.
These coordinates can be set by two types:
3.1 Pin position using metadata
The selected variable must have the x and y parameters inside the metadata parameter. x and y represent the coordinates where the pin will be displayed. This value goes from 0 to 1, so if you want to show the pin in the middle, send 0.5 for both x and y.
  "variable": "pin",
  "value": 21,
  "metadata": {
    "x": 0.5,
    "y": 0.9,
    "color": "cyan"
3.2 Pin position through editor
You can allow an editor, so your users can place pin positions, edit infobox content, and more.
4. Editor
You can enable users to edit pins. This editor is represented by the pencil icon located on the left side of the widget, and it only appears if any editing permission was assigned when editing the widget.
Changes made during editing are saved by clicking the save button, otherwise they are all discarded. The return buttons (arrow to the left) within the layer or pin do not discard the changes.
4.1 Tool box
The tool box has four main tools as:
  • Default tool: allows you to zoom and drag the image;
  • Add tool: This allows you to add a pin to the layer. When this tool is active, just click somewhere on the image. Note that the number of pins is limited by the data passed to the widget, so if your widget is of the basic type you will only have a reference pin to the added devices;
  • Edit tool: This allows you to edit a pin already added to the layer. When this tool is active, just click on a pin to edit it. Editing a pin includes editing data source, label, embed, img_pin and icon;
  • Delete tool: This allows you to delete a pin already added to the layer. When this tool is active, just click on a pin to delete it.
5. Infobox
Present more information with an infobox that'll automatically be associated with the pins, and customize it with images, external links, formulas, embed widgets, and much more.
    • Note Widget
    • Custom Widget
      Custom widgets allow developers to incorporate powerful content in their own widget for their dashboards. Creating your own The sky's the limit when using this widget. You can build your widget using Angular, React, Vue.js, or even plain old ...
    • Widget Header
      The widget header enables you to add customized buttons in the header of your widget in order to improve the flow of your dashboard. The widget header is enabled for all widgets. You can configure it by selecting the Header tab in your widget ...
    • Pie Widget
      Using data from multiples variables, the Pie widget automatically produces a Pie Chart, where each slice represents variable data. This widget also accepts features like metadata, that can be set in your variable data. Creating your own To add it to ...
    • Icons Widget
      With icons, the user can create very personalized widgets for their applications, and the result can look like the ones shown below, but the possibilities are endless. Users can add up to 9 variables in this widget, and each variable will show its ...
