Area Chart Widget
Area Chart Widget
Charts are a very powerful way to visualize your data and look for insights. You can also customize colors, apply Formula, customize the line shape (step or smooth), and more.
This widget also accepts features like metadata and series, that can be set in your variable data.
1. 'Data From' Field
When using a Blueprint dashboard, the field Variable will not list variables to be picked because it doesn't know the devices linked to your Blueprint Device.
2. Composing X-axis and Y-axis
In the area chart widget, it is possible to customize how the data will be displayed in the horizontal and vertical axis.
2.1 X-axis
By default, the X-axis of the chart will be the time of the values, and you can customize the range of time. But, sometimes you need to group your data through the X-axis even if they don't have the same time. To achieve this, you need to select a variable that contains the group and all data will be grouped by series.
Data is ordered by time ascending, but it is possible to change it to series
It is also possible to define the X-axis time range dynamically, using another variable data to achieve this. The variable data should look like the following payload:
  "variable": "time_range",
  "value": "Any value",
  "metadata": {
    "start_date": "2021-06-17T00:00:00.000Z",
    "end_date": "2021-06-18T00:00:00.000Z"
The  start_date  specifies the start of the range, and the  end_date  specifies the end of the range. In this case, the date and format should be in the ISO 8601 format.
2.2 Y-axis
In the vertical axis, it is possible to customize the scaling behavior, as it is possible to apply metric prefixes and abbreviations, change the step value (represents the difference between each tick), and more.
The Y-axis will automatically find the best scale for your data; it is not necessary to customize it, unless you want to do so.
You can set multiple Y-axis to your chart. Read more about Multiple Axes in Chart Widgets.
3. Filtering data
It is possible to pre-set some date filters to be displayed, and these filters can be in minutes, hours, days, weeks, months, or custom by choosing a date in the calendar.
4. Increasing performance
When a chart has a large number of data, it is possible to increase the widget performance by enabling the Downsampling feature. In addition, Downsampling can make the data easier to visualize.
Downsampling has two concepts, the Threshold and the Factor. The Threshold limits the amount of data to start the downsampling, and the factor is used to determine how many samples will be cut.
The greater the factor the greater the performance, but as the factor increases, the data also becomes less and less recognizable
    • Line Chart Widget
      Charts are a very powerful way to visualize your data and look for insights. You can also customize colors, apply Formula, customize the line shape (step and smooth), and more. This widget also accepts features like metadata and series, that can be ...
    • Multiple Axes in Chart Widgets
      All chart-type widgets in TagoIO can be configured to display more than one Y-axis. The widgets that supports this feature are Area Chart, Line Chart, Horizontal Bar, Vertical Column and Multiple Charts. Adding multiple axes to your chart You can set ...
    • Multiple Charts Widget
      Charts are a very powerful way to visualize your data and look for insights. You can also customize colors, apply Formula, customize the line shape (step and smooth), decide if they're to be stacked or not, and more. In a multiple charts, each ...
    • Widget Cache system
    • Card Widget
      Use Card to display the last value of a variable, its unit, and a mini-chart. Card accepts links so that when users click on it, it may redirect them to another website, dashboard, or tab.  This widget also accepts features like metadata, that can be ...
