Field Types for Input Form
The field is the structure that contains the relation between the inputted data and the Device data in some widgets.
Fields can have a bunch of types, depending on the widget that it is dealing with.
1. Text
A typical text input will appear, and the value will be anything that was typed into it.
2. Address
It will display a text field integrated with Google Maps to look for an address, and the values for this field will be the complete address selected and it will also have the location coordinates within it.
For the Input Form Widget, it is possible to enable a map under the input.
3. Calendar
It will display a calendar field that allows the user to enter a date, or a date range, as a value through a calendar popup. When receiving the user answer in your device, you will be able to get it in the value parameter and the metadata parameter. The latter one will be in date string format as start_date and end_date.
For example, the input above will produce the following payload:
  "variable": "location",
  "value": "Start: 2021-06-04T03:00:00Z, End: 2021-06-11-T02:59:59Z",
  "metadata": {
    "end_date": "2021-06-11T02:59:59Z",
    "start_date": "2021-06-04T03:00:00Z"
4. Checkbox
A traditional checkbox will appear and the value will be set as true (checked) or false (not checked)
5. Clock set
It will display a step button to select the hour range without the date.
6. Device
It will display a dropdown field with all an account's devices. The value of the field will be the id of the selected device.
InfoYou can customize the devices shown by the list through tags. Configuring tags will show only the devices with a tag correspondence.
7. Dropdown
It displays a dropdown menu with options that you define. The value of the field will be the selected options, and these options can be defined as static or dynamic with the dropdown being filled up with data coming from a variable. Learn more about Creating Dynamic Dropdown selection using Forms.
8. Dropdown Multiple
It displays a dropdown menu with options that you define. The value of the field will be the multiple options selected, and these options can be defined as static or dynamic with the dropdown being filled up with data coming from a variable.
9. Email
It displays a field to submit multiple emails, separated by a comma.
10. Entity & Entity Multiple
It will display a dropdown using values contained in your Entities. You are able to select which field from your entity should be displayed in the dropdown, as well as which field from your entity should be submitted when pressing the Submit button.
The difference between the Entity and Entity Multiple is that the last one allows you to select multiple values in the dropdown, instead of just one.
11. File Upload
It will display an option to upload files to TagoIO. These files will be stored in the files section under the folder devices/your_device_id/ by default. It is possible to restrict the number of files per upload, allow users to use their mobile camera, and more.
You can customize the path, however. For example, if you want to save the files in a folder called images and a subfolder called icons, you would need to type devices/your_device_id/images/icons
The variable that receives this data keeps the file name in the value parameter, and in the metadata it keeps the file's parameter. So sending a file will produce variable data like this:
  "variable": "file_variable",
  "value": "file_name.png",
  "metadata": {
    "file": {
      "md5": "md5_data",
      "path": "devices/your_device_id/file_name.png",
      "url": "your_file_url"
12. Filtered Variables
It will display a dropdown field, with options that change dynamically based on other fields. In the example below, the Food field changes based on the Food Type field. Learn more about Filtered Variables
13. Image / Video Select
Whenever you need to choose a value by using images instead of entering text, the image Field is the best option in form widgets. By entering media URLs into the options, the field will be filled with these images or videos and you will be able to select one or many of them. Learn more about Adding Image Selector field on Forms.
14. Incremental Step
It will display a step button to select a numerical value.
15. Radio
A traditional Radio input will appear. Once selected, you will be able to define its options with their labels and values. The value of the field will be one of the selected options.
16. Validation
This field type does not represent a form input value. Instead, the variable assigned to this field expects to receive text data that displays as a message above the form. The validation message supports four predefined types: warning, info, danger, and success. You can specify the message type by including a type property in the metadata object.
Info
By default, validation messages are displayed to all users viewing the widget. To target specific users, capture the User Session ID using the Capture User field and include the session_id parameter in the metadata object.
ParameterTypeRequiredDescription
typestringNoMessage type: warninginfodanger, or success
colorstringNoCustom color override. If not specified, color is determined by the type parameter
session_idstringNoUser session ID to target specific users. If omitted, message displays to all users
show_markdownbooleanNoEnables markdown rendering in the message text
Example
  1. {
  2.   "variable": "validation",
  3.   "value": "Your **data** had been succesfully updated!",
  4.   "metadata": {
  5.     "type": "success",
  6.     "color": "green",
  7.     "session_id": "USER_SESSION_ID",
  8.     "show_markdown": true
  9.   }
  10. }
17. Other fields
  • Barcode: It will display a field to type the barcode or scan it when using it through mobile or computer.
  • Capture user: It will capture user information, such as e-mail or name, so that you can use it in the Analysis later.
  • Hidden: For submitting data without user input, this variable will receive a static value, set by the field edit screen.
  • Number: It will display a text input, but it validates if a number was typed.
  • Password:  It will display a password input.
  • QR Code: It will display a field to scan a QR Code when using it through mobile or computer.
    • Input Form Widget
      The Input form allows users to submit values to variables through a form. Editing the form The Input form is a very dynamic widget. You can customize its colors, layout, text, and even icons. To edit a specific section of this widget, you must hover ...
    • Input Control Widget
      The Input control allows users to submit values to variables through a form. Editing the form The Input control is a very dynamic widget, as you can customize its colors, layout, text, and even icons. To edit a specific section of this widget, you ...
    • Form Fields Visibility
      Fields Visibility offers the possibility to control the visibility of certain fields in your Input Form widget. By using this feature, you are able to define conditions to hide some fields based on the values of other fields. For example, the field ...
    • Adding Image Selector field on Forms
      The Image Selector field type allows you to put an entry where the user can select one or many images with given values. Users will need to click on an image and the value you entered in the widget options will be stored in your data device. The most ...
    • Data Input Service
      Each time a device sends data to TagoIO, the system will count 1 Data Input Transaction for each variable. These data input transactions are counted against the Profile where your devices are located. You need to estimate the maximum number of ...
