Video Widget
Video Widget
The Video widget provides the ability to present custom videos in your dashboard. You can use it to present a company or customer video, or anything else that helps the user to better visualize your application.
1. Video Behavior
Video behavior is where you get the video URL from, and it can be three types: static, conditional, and dynamic.
You can use the TagoIO's file system to store the video, and cache the public URL.
1.1. Static
It displays the video from a static URL.
1.2. Conditional
Create conditions, where each condition will have a video URL associated with it, and if the variable linked in the Data from field satisfies this condition, this video will be displayed.
1.3 Dynamic
This video URL comes from the variable data.
2. 'Data From' Field
The conditional and dynamic behavior has a Data from field to set the device and variable that will be used.
2.1 'Data From' for Normal Dashboards
2.2 'Data From' for Blueprint Dashboards
    • Widget Cache system
    • Compose Widget
    • Custom Widget
    • Note Widget
    • Map Widget
